27 Mar 2008 at 15:45 #1 robgti robgti Associate Joined 17 Dec 2007 Posts 876 Location Easington Lane Just had these delivered, plugged them in and i am only getting sound from my right speaker. any ideas?
27 Mar 2008 at 16:13 #2 helmutcheese helmutcheese Permabanned Joined 19 Jun 2007 Posts 10,717 Location InURmama Yes, issue same as some of the 20's. You need open the speaker and connect the wire thats off (guess they are slack).
30 Mar 2008 at 00:25 #3 LadFromWales LadFromWales Associate Joined 14 Oct 2005 Posts 1,959 Location Pembrokeshire is the quality control on these really this bad?!
30 Mar 2008 at 14:26 #4 robgti robgti Associate OP Joined 17 Dec 2007 Posts 876 Location Easington Lane well i took it apart and couldnt see any wires off so i have had to plug the line in cable half way for them both to work
30 Mar 2008 at 16:06 #5 helmutcheese helmutcheese Permabanned Joined 19 Jun 2007 Posts 10,717 Location InURmama Sorry it was not same issue as the T20's. Are you sure its not your cable has the wrong poles ?. You may be simply getting Mono to both speakers now.
31 Mar 2008 at 15:04 #6 robgti robgti Associate OP Joined 17 Dec 2007 Posts 876 Location Easington Lane its the cable that came with the speakers so it should be the right one
