- 6 Mar 2004
- I.O.W
i'm having a bit of an issue with my creative inspire 6.1 6700 speakers, just got home from uni to find they dont work! certainly did this morning but have just plugged them up at home and nothing... tried literally everything, checked all the connections, computer settings (soundblaster audiology 2, tested with my brothers 5.1 speakers and works fine) so i got out the trusty multimeter. power cable is working (saw the led on the volume was working but just to check it was at full power) but nothing out of the speaker outputs.
there is also no 'pop' as i turn the power on and off, and out of desperation tried taking the power in and out when there were switched on; a big fat nothing!
the speakers are 2 years old and as such are out of the warrenty so i took the back off to check for bust fuse etc, nothing! and no wires to come loose etc so i'm at a loss! my only guess would be a bust power amp as the headphone connector on the volume control works fine.
any help would be much appreciated! (just on the off chance i'm missing something!)
T
T
