Have been using my on HD audio with my Asrock board since my Live 5.1 didn't seem to work bizarrely. I was more than happy with the output, but saw a good opportunity to buy on MM the fatality FPS (with Xram etc).
I installed it (had to select 2nd pci slot) and had turned off the onboard audio in the bios, but retained the HD audio drivers in case I needed to revert due to crackling etc. I ONLY used the latest drivers from the Creative website and not any of the apps, as I'd heard they were a bit of bloatware (will check them out later).
Note: I only currently have some pathetic 2.1 setup as the HC system is now downstairs with the plasma since my NF2 board (that I bought the HC system to play games with
) supported DD, but creative don't with games
Getting to the point
Anyway, I tried BF2 and couldn't really discern any difference in sound quality even with it on ultra and EAX5, so I tried COD4. What I noticed was that before my fps was hovering just above 60fps in bad situations, and then going to 90+ (had seen 200fps on occasion), but now I was getting on average 50-55fps, and dipping to say 43fps at times.
Have I done something wrong on the installation as I thought that the creative board was meant to speed things up (take some of the strain from the CPU etc). Bit dissappointed at this stage as I was hoping for a slight increase in frames and not a reduction.
Matthew
Matthew
