Creative X-Fi XtremeMusic Issue
17 Nov 2003
West Sussex
Ive just installed my new sound card and can't seem to get it to work. A read reviews on the card before buying, but now I'm worries these reviewers were misinformed.
Does this card have an S/PDIF output? The reviews i read stated that the "Flexi Jack" port at the rear of the card is S/PDIF. I bought a mono jack to RCA converter and connected it to my amp - nothing. The sound card doesn't even know it is there.
WTF is going on? I find the Creative site extremely lacking in detailed infomation.
Does this card have an S/PDIF out on the back or what? :confused:
Any help greatly appreciated.
I'm running Vista. I don;t see an option to do that.
I've told Vista that I want to use S/PDIF. That worked fine with the on board sound.
Yes. Everything installs fine. S/PDIF worked fine on the on board sound card, so it is nothing outside the PC causing the issue.
From what you say though - that connection at the rear is an S/PDIF - so at least I know my card should do what I want it to do.
Anyone using a Creative card with S/PDIF on Vista?
ive got a feeling SPDIF is disabled in the Vista drivers as well because creative couldnt make good drivers if they tried
In the main X-Fi Vista settings bit (not the S/PDIF bit or the Audio Console) there's a tick box on one of the option pages to enable Digital I/O. You need to do this before the S/PDIF will work.
