Heya, basically which of those would you stick in you system, runnign Vista Home Premium 64 bit.
I'm trying to spec a PC, and currently using onboard sound (Nforce 2 Soundstorm) to hook my comp up to AV via optical. However this isn't needed (although the option to use them speakers in the future would be good).
Currently have a set of 6.1 Creative speakers that use standard analog pin outs that I'd like to use, and preferably have EAX, however I know the Xi-Fi's seem to be very hit and miss, with some people having to swap the parts out due to it sounding like a bowl of rice crispies - where as others seem to be running fine.
Basically I'm looking for a good card, with working drivers and preferabbly EAX5 but I think the xonar is the only card that seems to work well and I guess that, like the Soundstorm only does EAX 2?
Anyway, cheers for any help
