*Cries* Memtest86 help, please?
12 Jun 2005
A lake!
Can anyone give me direct links (if possible) to create a boot CD for windows XP with Memtest 86 on please? I've tried loads, but all my attempts have failed.
Thanks!
i think this is the one CLICK ME
i cant remember 100% but i think unzipped then opened the iso with nero and it auto done it for me last time.
if that fails this one works in windows (but i dont think its quite as good) CLICK ME
Can I just stick this on a CD or do I have to do anything else?
Previous attempts have failed because I can't make a boot disk. :(
Thanks for the file stigggeh!
I have just checked the one above. It opens Roxio for me, if I double click it it lets me burn a boot disc. Set your boot priority to cd/dvd drive and it should start at boot up. Hope this helps :)
Yup - extract the .iso image and burn the IMAGE (not the file itself) to the disc - so many people fall down on that - using something like Nero, Alcohol, Roxio etc.
Wow you guys stay up late. Thanks though.
When I did it, it said that there were files attatched that may/will (don't remember which) be lost. I'm off to try it anyway.
EDIT: Just tried it and when I try to boot from the CD it just ignores it. Any ideas?
