- 25 Mar 2004
- Fareham
Working on an internal site for work, this site will be used for monitoring things like disk space, backups etc for all our exchange servers.
Some points:
So far this is what I have:
http://i54.tinypic.com/157130h.jpg
Any ideas/crits welcomed, i'd say i'm fairly happy with the overall layout, it's not that exciting but it's streets ahead of how it looks atm in my opinion.
Thanks!
Some points:
- This is only internal, no customer at the end of this, can do what I want
- This curently uses a 2 row tab menu system, if you change the option at the top row the 2nd row also changes. The top row uses jQuery tabs, the 2nd row is just styled with CSS.
- I've included a screenshot with a couple of tabs selected so you can see a page in action.
- The content will be driven by CSV file paths stored on the web server, these dynamically fill in the content. the CSV files are generated by various scripts we write to take data from various servers.
- Table is using tablesorter with the Zebra widget enabled for striping the styles on alternate rows.
Thanks!
