Nope' it's for a large IT firm.
It's more like an IQ test - example question from the practise run I just did.
Six years ago Annabelle was twice as old as Jason was. Now, Annabelle is four years older than Jason. How old is Jason now?
A: 8
B 10
C: 14
D: 4
Question seems fine, when you have time to reflect and read correctly but 50 of these in 15 minutes is tough going!
Then other questions are which shape matches, this if turned on it's side etc while others are focused on things like:
ASSENT is the opposite of
AGREEMENT
CLIMB
COOPERATION
REFUSAL
NEGATION
Ahh, fair dos, kai. The acronym rang of something military, but it appears to be just a package of tests HR people buy from some US company. Not to worry. Under various names, I've done a few of these aptitude juggles over the years, and they are both much easier and closer to practice questions than people think. What you have here is a standardised literacy and numeracy test, proxying for intelligence. Although vocabulary checks are a tad cheeky in this regard.
A few tips then:
-- You have a couple of minutes per question -- use them, and read each question twice.
-- Don't be a hero and use pen and paper if allowed; you'd be surprised at gaffes people make under stress.
-- Scan for relevant information but do not be lead by the answers: they include common errors people make from misreading the problems.
-- Leave difficult/longer questions you cannot immediately answer; likewise if you'd spent 3 minutes on getting an answer not in the list of options -- do not go down a negative spiral -- you will waste time.
-- My personal strategy was always: language, logic, arithmetic/algebra, probability and then patterns and situations.
-- You may find a different sequence plays to your strengths better, as most of these tests can be taken in any order.
-- When finished with the questions you are certain about, come back, look at the time, and proceed with either: (a) guess if not penalised for doing so; (b) if you have enough time, do try to calmly go through the wording and reason through the remaining problems; (c) if penalised for guessing, do what you can with the extra time on the questions you can make at least some progress on -- don't worry about the blanks you really don't know.
-- If taking the test at home, without restrictions on your internet use or other technology, do use the tools available, but be mindful of the time it takes.
-- You don't have to get them all right nor are expected to, in most cases; the key is getting more than an average result for the test (normally 24-28 questions right for a technical job, and doing X standard deviations [1-2 questions per level] to get up to a standard the company interviews); no penalties for being a top dog though.
Example of a question you should probably skip at first passing:
You're in prison, one hundred inmates in total, and are told that you will be set free if you win a simple game: there's a room with a lever in it which you can only flip on and off; inmates will be picked at random and lead into this room one at a time with no means to communicate after the game starts; should you think everyone's been to the room at least once, you can tell the guard, who will set you all free if the shout is correct, and gas you if not. You are given time to discuss strategy before the game begins. What's your plan for winning the game?
It's a probability thing and the answer is online for an insane variety of the situation and wordings. So you're unlikely to find something like this on a test any more, but be wary of wordy word problems that expect a trick to crack them!
Good luck!
