I havn't built a computer since early 2008 and havn't really kept up to date since then so I'm not entirely sure what is what, although I've learnt a lot in the past 48 hours of googling.
Mobo : Asus P8Z68-V PRO Z68 Socket 1155 8 Channel HD Audio ATX Motherboard
CPU : Intel Core i5 2500K 3.3GHz Socket 1155 6MB Cache Retail Boxed Processor
RAM : Corsair Vengeance 8GB (2x4GB) DDR3 1600Mhz CAS8 1.5V Non-ECC Unbuffered
Graphics Card : Gigabyte GeForce GTX 480 SUPER OC 1536MB GDDR5 PCI-Express Graphics Card
Picked the i5 as I hear the the i7 is a bit overkill and only very slightly better for quite a higher price.
I picked the card as I hear it is actually better than a 570 although ready to be corrected? 580s are out of my budget and I found it very difficult to pick between 480 and 570 but the 480 did have more memory.
My mobo choice was not exactly scientific, I have had ASUS mobos for a while with no probs so want to stick with them but got very confused with the difference between P67 and Z68 chipsets. As i understand it the P67 wont run 1600Mhz RAM as standard and needs fiddling with but the Z68 will just plug and play 1600Mhz RAM? So thats why I went with a Z68 board.
RAM choice well 1600MHz seems the best compromise in performance to price. But don't know why I should pick Vengance over XMS3 or even how much "better" the more expensive 8-8-8-24 Vengance is over the 9-9-9-24?
So what I need to know is am I creating a bottleneck anywhere, are these components fairly well matched? This will be a gaming pc I generally play Crysis, Metro 2033 etc at 1920x1080 etc but tbh have been put off buying some new games as I don't think my current Q6700 and GTX 260 would be up to it. So it needs to be a sort of mid to high range comp.
Also will it all fit inside the Antec 900 case I already have and stay cool and will my current 650W PSU be enough?
I realise this is quite a long post so congratulations for getting this far and thanks for any help in clarifying things!
