Hi All,
I'm starting to make plans for building a new PC in the next month or so and want some advice on a build. I currently have a pre-built system I purchased from Overclockers 5 years ago thats still going strong, but it is starting to show its age.
I've done quite a lot of reasearch and come to the conclusion that the below seems to be a good combination, but I'm wondering if theres anything I should up/downgrade.
I dont need a graphics card as for the time being I'm going to move the GTX470 from my current PC into my new build as I think it still holds its own. I'll most likely be looking to upgrade that around 12 months after buying all of this which I think should see me a bigger jump in overall performance.
I do want the system to be as quiet as possible which is why I was thinking of the pre noise dampened case. I don't need it to be silent, but the more I can keep the noise level down the better.
In terms of storage hard drives / optical drives, these will all be moving from my current PC. I have two 1TB and two 500GB hard drives that will all move across to give me all the storage I need.
I do currently have a wireless network card and sound card but they are both PCI which the board I've gone for doesnt support, so I figure I need both of those as well.
Any advice will be appreciated
In terms of budget I absoultely cannot go over £1200.
Thanks
In terms of budget I absoultely cannot go over £1200. Thanks
