- 18 May 2010
Hi,
I've gone back to air and getting higher temps than anticipated, I think I know the reason but wondered if you guys could could confirm please.
Case is fractal define s
Cpu amd 8350 @4.2 stock volts llc medium
2 x 140mm intakes
Exhaust is 120mm aio from my gpu
Cpu cooler is scythe mugen 140 mm fan
Temps are just shy of 62c in bf4, too high for my liking consider the standard cooler kept it below 60c with the same OC in my old case
Do you think that having an aio as the exhaust is causing the hot air to build up in the case as its limiting how quickly it can expel the air? Only thing that makes me think its not that is vrm temps are fine and had the same exhaust setup in my old case.
Thanks
2 x 140mm intakes
Thanks
