Critique my "instead of a nuc" idea
5 Nov 2011
Derbyshire
Hi,
Wondering if the guru's can take a gander over this, looking to build something to fit under my "desk shelf" It will sit under my monitor shelf which the legs are approx 100MM high.
It will be used to drive my second screen and will only run a Linux distro. I've gone for an i3 with HT because I want it to be extremely nippy.
NUC seems the best size but for I'd want an i5 NUC and they come in at around £400 fully specced.
Any adjustments to this?
YOUR BASKET
1 x Intel Core i3-4130 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £82.99
1 x Asus H81I-Plus Intel H81 (Socket 1150) DDR3 Mini ITX Motherboard £58.99
1 x Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP4G3D1609DS1S00CEU) £53.99
1 x SuperFlower Golden Green HX 350W "80 Plus Gold" Power Supply - Black £44.99
1 x Kingston 60GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/60G) £39.95
1 x Silverstone Milo ML05B HTPC Case - Black £33.95
Total : £324.46 (includes shipping : £8.00).
Hi,
YOUR BASKET
I don't that power supply fits in that case, I think the case only takes SFX power supplies.
Would recommend the Antec ISK310-150 or ISK300-150 as an alternative like this http://www.overclockers.co.uk/showproduct.php?prodid=CA-209-AN&groupid=2362&catid=160
