critique my potential build please
Man of Honour
26 May 2012
been too long since i built my own desktop...need some advice etc pretty plz
Intel Core i5 3570K
Asus P8Z77-M PRO Z77 miniATX
Samsung Green 2x4GB
MSI HD 7850 Power Edition Twin Frozr IV
Crucial RealSSD M4 256GB
Samsung SH-S222BB/BEBE 22x DVD±RW SATA ReWriter
Fractal Define Mini (yes, i want a mini case)
Antec High Current Gamer M 620W
OcUK H²Flo Extreme Liquid Dual Fan CPU Cooler
+ a few fans
OS monitor keyboard mouse speakers i have
am i missing anything out/can change?
looks pretty good to me, pretty sure you can easily fit a h100 in the top if you want/can afford one, maybe the non pro version of the mobo
yea i saw the prodigy, i did consider it, but i was wondering how loud it'll sound. i wanted a reasonably silent build as i'll have the desktop in my bedroom
yea i was considering the pro/non-pro version and also the Gigabyte Z77MX-D3H, no idea which mobo i should settle on.
i think the h100 is overkill. im looking for a 4.4ghz oc with no overvoltage, so anything which can keep the temp below 70 celsius would be a charm, and the radiator can be mounted to the rear exhaust fan, so 1 less fan in the system xD
