Have been doing this routine since the start of the year:
Chest & Back
Incline Dumbbell Bench Press
Dips
Lat pulldown
One-Arm Rows
Flat Barbell Bench Press
Legs
Squat
Leg Press
Calf Raises
Shoulders & Arms
Seated Dumbbell Shoulder Press
Dumbbell Lateral Raises
Dumbbell Curls
Tricep Pushdowns
Forearm Raises (think that's what they're called off the top of my head)
And using 5*10 as suggested here:
http://forums.overclockers.co.uk/showthread.php?t=17960505&highlight=startername_DaWG
Before anyone posts about the lack of Deadlifts etc, as explained in the linked thread I'm slightly limited as to what exercises I can do at my gym. Anyway, the gym has been under repairs for the past 6 weeks or so and it's just re-opened so I'm back down there again tonight
I've read that it's good to change your routine from time to time, so the point of my post was to see if anyone could suggest any good alternative exercises to what's listed above / any changes to the routine?
Also, as posted above I've being doing 5 sets of 10 reps which is apparently better for building size (I personally care a lot more about the size I put on than the strength I gain), but i wanted to make sure I was okay with what I've been doing. Five sets on my 10 rep max weight would kill me, so I've been using one set as a warmup set on a weight I know I can easily do, the second a little under what my max is, the third and fourth at my max, then the fifth I try and push the weight up more and normally manage about 5-8 reps, so for instance on Incline DB Bench Press, I'd do a set each of; 18, 20, 22, 22, 24 etc... Is it right to be doing this?
Oh, and if it helps I'm a tad under 6 foot and 80KGs.
Many thanks in advance. X
Chest & Back
Dips
Lat pulldown
One-Arm Rows
Legs
Squat
Leg Press
Calf Raises
Shoulders & Arms
Dumbbell Curls
Tricep Pushdowns
