Cron command help
12 Jan 2004
Londinium
I have a cron job that runs every 15 minutes that runs a php script which broadcasts any email campaigns that have been scheduled. The command is:
Code:
lynx -dump http://www.*******.co.uk/scripts/broadcast.php
It works fine, but the only problem is that I am emailed the output everytime the script runs. You can imagine that they can build up being sent every 15 mins of every day! The emails are almost always blank as the script runs with no errors. However, what I would really like is to only be emailed when an error has occured, and so the cron output would not be blank. Is there anyway to modify the cron job command to make this happen?
Pine said:
You need to redirect the script output to /dev/null. Have a look at the crontab article on Wikipedia.
So the command would be:
Code:
lynx -dump http://www.*******.co.uk/scripts/broadcast.php >/dev/null 2>&1
But wont that stop all email output? I still want to be emailed when an error occurs, just not when no error occurs.
Code:
lynx -dump [url]http://www.*******.co.uk/scripts/broadcast.php[/url] 1> /dev/null
Try that.
edit: Actually, I doubt that would work, do you have access to the php command line program thingy?
Pine said:
Code:
Try that.
Well its just the standard cpanel thing for my web host (tsohost), so I doubt it.
Give it a bash:
Code:
php -f /home/you/path/to/file.php 1> /dev/null
Pine said:
Give it a bash:
Code:
Okay it seems to work i.e. not sending me emails when they are no errors. But, I changed the username of the db connection line in the script to force an error, and this is what I got mailed:
Code:
*** glibc detected *** php: double free or corruption (!prev): 0x0000000000a42310 ***
======= Backtrace: =========
/lib64/libc.so.6[0x3c14f6ae4f]
/lib64/libc.so.6(__libc_free+0x6e)[0x3c14f6b38e]
php(destroy_zend_class+0x62)[0x56f322]
php(zend_hash_destroy+0x38)[0x57ac08]
php(zend_shutdown+0x4d)[0x57618d]
php(php_module_shutdown+0x25)[0x549d75]
php(main+0x4b0)[0x593170]
/lib64/libc.so.6(__libc_start_main+0xef)[0x3c14f1c40f]
php[0x433fb9]
======= Memory map: ========
00400000-00738000 r-xp 00000000 08:02 7089046                            /usr/bin/php
00837000-00898000 rw-p 00337000 08:02 7089046                            /usr/bin/php
00898000-008b5000 rw-p 00898000 00:00 0
00997000-009a9000 rw-p 00397000 08:02 7089046                            /usr/bin/php
009a9000-00ba7000 rw-p 009a9000 00:00 0                                  [heap]
37a2d00000-37a2e29000 r-xp 00000000 08:02 7087294
/usr/lib64/libxml2.so.2.6.22
37a2e29000-37a2f28000 ---p 00129000 08:02 7087294
37a2f28000-37a2f35000 rw-p 00128000 08:02 7087294
37a2f35000-37a2f36000 rw-p 37a2f35000 00:00 0
37a3000000-37a3032000 r-xp 00000000 08:02 7087069
/usr/lib64/libxslt.so.1.1.8
37a3032000-37a3131000 ---p 00032000 08:02 7087069
37a3131000-37a3133000 rw-p 00031000 08:02 7087069
37a3200000-37a3237000 r-xp 00000000 08:02 7087437
/usr/lib64/libcurl.so.3.0.0
37a3237000-37a3337000 ---p 00037000 08:02 7087437
37a3337000-37a3339000 rw-p 00037000 08:02 7087437
37a3400000-37a34c2000 r-xp 00000000 08:02 7087413
/usr/lib64/libsablot.so.0.100.1
37a34c2000-37a35c1000 ---p 000c2000 08:02 7087413
37a35c1000-37a35ca000 rw-p 000c1000 08:02 7087413
37a3600000-37a360f000 r-xp 00000000 08:02 7087403
/usr/lib64/libexslt.so.0.8.6
37a360f000-37a370f000 ---p 0000f000 08:02 7087403
37a370f000-37a3710000 rw-p 0000f000 08:02 7087403
37a3800000-37a382e000 r-xp 00000000 08:02 7087398
/usr/lib64/libmcrypt.so.4.4.7
37a382e000-37a392d000 ---p 0002e000 08:02 7087398
37a392d000-37a3931000 rw-p 0002d000 08:02 7087398
37a3931000-37a3937000 rw-p 37a3931000 00:00 0
3a45e00000-3a45eda000 r-xp 00000000 08:02 7089377
/usr/X11R6/lib64/libX11.so.6.2
3a45eda000-3a45fd9000 ---p 000da000 08:02 7089377
3a45fd9000-3a45fdf000 rw-p 000d9000 08:02 7089377
3a46000000-3a46010000 r-xp 00000000 08:02 7084960
/usr/X11R6/lib64/libXext.so.6.4
3a46010000-3a46110000 ---p 00010000 08:02 7084960
3a46110000-3a46111000 rw-p 00010000 08:02 7084960
3a46200000-3a46248000 r-xp 00000000 08:02 7087588
/usr/lib64/libmysqlclient.so.14.0.0
3a46248000-3a46348000 ---p 00048000 08:02 7087588
3a46348000-3a46428000 rw-p 00048000 08:02 7087588
3a46428000-3a46429000 rw-p 3a46428000 00:00 0
3a46800000-3a46816000 r-xp 00000000 08:02 7084948
/usr/X11R6/lib64/libXpm.so.4.11
3a46816000-3a46915000 ---p 00016000 08:02 7084948
3a46915000-3a46916000 rw-p 00015000 08:02 7084948
3c14d00000-3c14d1a000 r-xp 00000000 08:02 5701641
/lib64/ld-2.3.6.so
3c14e19000-3c14e1a000 r--p 00019000 08:02 5701641
/lib64/ld-2.3.6.so
3c14e1a000-3c14e1b000 rw-p 0001a000 08:02 5701641
/lib64/ld-2.3.6.so
3c14f00000-3c1502e000 r-xp 00000000 08:02 5701645
/lib64/libc-2.3.6.so
3c1502e000-3c1512d000 ---p 0012e000 08:02 5701645
3c1512d000-3c15131000 r--p 0012d000 08:02 5701645
3c15131000-3c15133000 rw-p 00131000 08:02 5701645
3c15133000-3c15137000 rw-p 3c15133000 00:00 0
3c15200000-3c15202000 r-xp 00000000 08:02 5701677
/lib64/libdl-2.3.6.so
3c15202000-3c15302000 ---p 00002000 08:02 5701677
3c15302000-3c15303000 r--p 00002000 08:02 5701677
3c15303000-3c15304000 rw-p 00003000 08:02 5701677
3c15400000-3c15484000 r-xp 00000000 08:02 5701685
/lib64/libm-2.3.6.so
3c15484000-3c15584000 ---p 00084000 08:02 5701685
3c15584000-3c15585000 r--p 00084000 08:02 5701685
3c15585000-3c15586000 rw-p 00085000 08:02 5701685
3c15600000-3c15614000 r-xp 00000000 08:02 7084438
/usr/lib64/libz.so.1.2.2.2
3c15614000-3c15713000 ---p 00014000 08:02 7084438
3c15713000-3c15714000 rw-p 00013000 08:02 7084438
3c15800000-3c15811000 r-xp 00000000 08:02 5701663
/lib64/libresolv-2.3.6.so
3c15811000-3c15911000 ---p 00011000 08:02 5701663
3c15911000-3c15912000 r--p 00011000 08:02 5701663
3c15912000-3c15913000 rw-p 00012000 08:02 5701663
3c15913000-3c15915000 rw-p 3c15913000 00:00 0
3c15a00000-3c15a21000 r-xp 00000000 08:02 7085251
/usr/lib64/libjpeg.so.62.0.0
3c15a21000-3c15b21000 ---p 00021000 08:02 7085251
3c15b21000-3c15b22000 rw-p 00021000 08:02 7085251
3c15c00000-3c15c05000 r-xp 00000000 08:02 5701746
/lib64/libcrypt-2.3.6.so
3c15c05000-3c15d04000 ---p 00005000 08:02 5701746
3c15d04000-3c15d05000 r--p 00004000 08:02 5701746
3c15d05000-3c15d06000 rw-p 00005000 08:02 5701746
3c15d06000-3c15d34000 rw-p 3c15d06000 00:00 0
3c16000000-3c16002000 r-xp 00000000 08:02 5701689
/lib64/libcom_err.so.2.1
3c16002000-3c16101000 ---p 00002000 08:02 5701689
3c16101000-3c16102000 rw-p 00001000 08:02 5701689
3c16200000-3c16202000 r-xp 00000000 08:02 7081092
/usr/lib64/libkrb5support.so.0.0
3c16202000-3c16302000 ---p 00002000 08:02 7081092
3c16302000-3c16303000 rw-p 00002000 08:02 7081092
3c16400000-3c1640d000 r-xp 00000000 08:02 5701688
/lib64/libgcc_s-4.0.2-20051126.so.1
3c1640d000-3c1650c000 ---p 0000d000 08:02 5701688
3c1650c000-3c1650d000 rw-p 0000c000 08:02 5701688
3c16600000-3c16614000 r-xp 00000000 08:02 5701735
/lib64/libnsl-2.3.6.so
3c16614000-3c16713000 ---p 00014000 08:02 5701735
3c16713000-3c16714000 r--p 00013000 08:02 5701735
3c16714000-3c16715000 rw-p 00014000 08:02 5701735
3c16715000-3c16717000 rw-p 3c16715000 00:00 0
3c16800000-3c16816000 r-xp 00000000 08:02 7087058
/usr/lib64/libgssapi_krb5.so.2.2
3c16816000-3c16915000 ---p 00016000 08:02 7087058
3c16915000-3c16917000 rw-p 00015000 08:02 7087058
3c16a00000-3c16ada000 r-xp 00000000 08:02 7084260
/usr/lib64/libstdc++.so.6.0.7
3c16ada000-3c16bda000 ---p 000da000 08:02 7084260
3c16bda000-3c16be2000 rw-p 000da000 08:02 7084260
3c16be2000-3c16bf5000 rw-p 3c16be2000 00:00 0
3c16c00000-3c16c35000 r-xp 00000000 08:02 5701723
/lib64/libssl.so.0.9.7f
3c16c35000-3c16d35000 ---p 00035000 08:02 5701723
3c16d35000-3c16d3a000 rw-p 00035000 08:02 5701723
3c16d3a000-3c16d3b000 rw-p 3c16d3a000 00:00 0
3c16e00000-3c16e70000 r-xp 00000000 08:02 7087057
/usr/lib64/libkrb5.so.3.2
3c16e70000-3c16f6f000 ---p 00070000 08:02 7087057
3c16f6f000-3c16f74000 rw-p 0006f000 08:02 7087057
3c17000000-3c17022000 r-xp 00000000 08:02 7087056
/usr/lib64/libk5crypto.so.3.0
3c17022000-3c17121000 ---p 00022000 08:02 7087056
3c17121000-3c17123000 rw-p 00021000 08:02 7087056
3c17200000-3c1730a000 r-xp 00000000 08:02 5701701
/lib64/libcrypto.so.0.9.7f
3c1730a000-3c1740a000 ---p 0010a000 08:02 5701701
3c1740a000-3c17428000 rw-p 0010a000 08:02 5701701
3c17428000-3c1742c000 rw-p 3c17428000 00:00 0
3c17500000-3c1757f000 r-xp 00000000 08:02 7081066
/usr/lib64/libfreetype.so.6.3.7
3c1757f000-3c1767f000 ---p 0007f000 08:02 7081066
3c1767f000-3c1768c000 rw-p 0007f000 08:02 7081066
3c17900000-3c17921000 r-xp 00000000 08:02 7087059
/usr/lib64/libexpat.so.0.5.0
3c17921000-3c17a20000 ---p 00021000 08:02 7087059
3c17a20000-3c17a23000 rw-p 00020000 08:02 7087059
3c17b00000-3c17b26000 r-xp 00000000 08:02 7087067
/usr/lib64/libpng12.so.0.1.2.8
3c17b26000-3c17c26000 ---p 00026000 08:02 7087067
3c17c26000-3c17c27000 rw-p 00026000 08:02 7087067
2aaaaaaab000-2aaaaaaac000 rw-p 2aaaaaaab000 00:00 0
2aaaaaab8000-2aaaaaac4000 rw-p 2aaaaaab8000 00:00 0
2aaaaaac4000-2aaaaaacf000 r-xp 00000000 08:02 5701858
/lib64/libnss_files-2.3.6.so
2aaaaaacf000-2aaaaabce000 ---p 0000b000 08:02 5701858
2aaaaabce000-2aaaaabcf000 r--p 0000a000 08:02 5701858
2aaaaabcf000-2aaaaabd0000 rw-p 0000b000 08:02 5701858
2aaaaac00000-2aaaaac21000 rw-p 2aaaaac00000 00:00 0
2aaaaac21000-2aaaaad00000 ---p 2aaaaac21000 00:00 0
7fffff96e000-7fffff982000 rwxp 7fffff96e000 00:00 0                      [stack]
7fffff982000-7fffff984000 rw-p 7fffff982000 00:00 0
ffffffffff600000-ffffffffffe00000 ---p 00000000 00:00 0                  [vdso]
/bin/sh: line 1:  9717 Aborted                 php -f
/home/olympus/public_html/scripts/broadcast.php >/dev/null
Not very usefull! Is there any way to get it to email the php error message rather than a memory dump?
Edit: I corrected the script and im still getting these errors, so it looks like its not working. Note that the script itself is working when I run it straight from the browser.
Beansprout said:
Do error handling within the script. Take the cron to /dev/null as above and have the script use mail() if there's any errors :)
Can you give me a quick example of this (error catching and mailing)?
Don't use php -f, use lynx -dump :D - more handy as you'll be running as the webserver user which, if phpsuexec isn't enabled, means there'll be no permissions conflicts (and if phpsuexec is enabled it doesn't matter either way).
As for error handling, would need to see the script for that. But mail() returns false if it hits an error so presumably that's the sort of thing you're after, so you can use a simple if():
Code:
if(!mail($foo,$bar,$lol,$zor)) {
mail(...)
So in other words, if mail() fails then ask it to send an e-mail to you (you, of course, have to define what goes in the mail :)
For more advanced things you can use set_error_handler() which is quite good fun :)
Code:
mail(...)
Thanks Beansprout. I have just a few more questions:
1.) For a command like:
Code:
$conn = mysql_connect("localhost", "user", "pass") or die('Connection Error: ' . mysql_error());
How could I catch this and send an email with a description of the error?
2.) Is there any variable that gives you a description of the general error that last occured, that could be used in your 'mail' example to give a description of the error that occured?
Edit: what I really want is to be emailed the output of the script (but not when the output is blank), i.e. a message like the following:
Code:
Warning: mysql_connect(): Access denied for user 'user'@'localhost' (using password: YES) in /home/olympus/public_html/scripts/broadcast.php on line 7
Connection Error: Access denied for user 'user'@'localhost' (using password: YES)
