cron job help
We don't know the structure of your hosting account so cannot confirm. If you have terminal access you can check if that is correct path by running the following command:
ls -lrt /home/username/public_html/folder1/folder2/execute.php
If that command find the file then the path is correct. If you don't have terminal access then try it and see if it works.
The path will be listed either under your control panel or do a $_SERVER['DOCUMENT_ROOT'] from within the directory and it'll list the path (alternatively just create a phpinfo(); page).
