- 12 Feb 2006
- Surrey
i've never used cron before so unsure what i'm doing wrong, but unfortunately the script i've got from online doesn't work.
below is the script i have which is save as 'mysql_autobackup.sh'
i've edited out some bits.
then on cronjobs i have the following to run sunday at 4am using the following.
but nothing happens. i checked the folder and no backup there. is there a way to see why it failed?
one thing i'm not sure on if where it says "mydb >" i assumed this was my database name so put that there, but then it has the .sql so wasn't convinced i was correct.
thanks
Code:
#!/bin/sh
#change directory to your backup directory
cd /home/websiteNameFolder/db_backup/;
#get backup of database of applications
mysqldump --user='[removed username]' --password='[removed password]' mydb >databaseName.sql;
#compress it in zip file
zip app_database-$(date +%Y-%m-%d-%H:%M).sql.zip tmp_db.sql;
#remove sql file
rm -rf tmp_db.sql;
#delete backups older than 20 days
find /home/websiteNameFolder/db_backup/app* -mtime +30 -type f -delete;
Code:
0 4 * * 0
Code:
/home/websiteNameFolder/db_backup/mysql_autobackup.sh
thanks
