Cron job
16 Oct 2007
UK
Hello all,
I want to back up a very miniscule database hourly onto my server - it's running cPanel, and thought about doing it with a cron job.
Any tips?
Well, i created cron.sh
#!/bin/sh
DATE=`/bin/date +"%G%m%d"` ;
mysqldump --host=localhost --user=******_address --password=******* --database=*********** --single-transaction --quick | gzip > ./public_html/tmp/backup-$DATE.sql.gz ;
And then in the cPanel cron box, I just put the path to cron.sh
(home/******/cron.sh)
Told it to run every minute, so I could see if it did anything, but nope!
i wouldn't have used 'cron.sh' as the name of the script.
can you run you script manually to see if it works? If it does then maybe its' a problem with cpanel. Also often things just not working is down to permissions check them.
Renamed, thank you
Also a slight issue where I don't have shell access to run the script to test, although apparently the cron is still able to run it. Looking at the email report, it does seem to be a permission error. Will look further! thanks for that
