Cronus Device (Multiplatform USB Adapter Xbox/Ps3/Wii/PC)
Posted in someones thread about Ps3 controls on PC, but not sure how many console guys look at the PC section. This device has been brilliant for me and may help others looking for cross platform control needs. I'm also pretty sure not many people have heard of this device.
http://www.cronusdevice.com/
Stumbled upon this magical little gadget a few months ago and its amazing. It basically allows most of the popular input devices to be used on the PC and both consoles. Its not exactly cheap but if you use multiple systems like me and prefer different control methods its a life saver.
It also has inbuilt buttom mapping set to profiles, so you can switch mapping mid game ie Ps3 controller often uses R1 L1 to fire, while Xbox 360 uses RT LT (R2 L2 equivalent). Using this you can get around games which support no remapping. I have PS button + Select mapped to cycle profiles.
The website explains it better, but it comes in two variants. The basic one and the Xtreme which supports MODs. I brought the Cronus Device regular from the rainforest named book store.
The Cronus Device is just a small usb stick that comes with a micro bluetooth adapter to plug in the end. It has two pieces of software CronusCFG, for buttom remaping and Bullseye for specifically mapping m&k to various controllers. These are loaded as profiles while the Cronus is plugged in your PC, then different ones are activated on the fly when your on other devices. All gamepads work out of the box default ie Ps3 and Xbox have 1:1 mapping so people may not need touch the software.
I personally use it for ps3 on 360 and Ps3 on PC, but have tested it with friends using 360 on Ps3.
