Hi
Not sure if this should be here or on the system board forum
I would be grateful if someone can clear this up for me please, I have just ordered this board http://www.overclockers.co.uk/showproduct.php?prodid=MB-465-AS&groupid=701&catid=1903&subcat=1782
And on the spec it mentions it supports Hybrid CrossFireX, I being a novice thought that this should work with the on board and a dedicated card but someone has just told me that you cant cross fire the on board with the dedicated card. He said that it is mentioned this because you could fit 2 ati cards and cross fire them.
If this is true then I will ditch the idea of getting an HD 5770 and get a 450gts.
Thanks
Thanks
