I am using molex adapters so i can use 2 graphics cards for crossfire..... But my question is.... My molex adapters are double ended... do i make sure both are plugged in before plgging the 6pin into my graphics card or just make some 1 end is plugged in? Thanks in advance
one end i will use then that was my only problem that was worrying me! thanks buddy! would appreciate what you think about power supply though as amd recommend it as 600w minimum and my psu is a decent one 70 pounds....
