Cross fire @ x4?
Permabanned
6 Feb 2010
Barnsley
Hi it the words of my manual "support for 2 way AMD CrossFire™ (running at x16, x4 bandwidth)"
is there any point running a second card at x4? i was looking for a cheap upgrade. and used card will be cheaper then a new card if i can get away with it
i have asked this question before and iirc there might be a 5-10% reduction in performance using the second card in a 4x slot.
Probably not noticeable when gaming but if you bechmark etc you would want a better board to squeeze those extra points out of it.
Yes the difference on 3.0 is less than 5%, you shouldn't care about it at all.
Maybe it will be bigger with more bandwidth-demanding cards like 780 TI's or 7990's, but if you x-fire anything "Normal", you won't see it at all.
