Does anyone know if it is possible to mount a titan fenrir onto an i7 with the assembly rotated through 90 degrees so that the fan is facing the top of the case.
I have a skeleton case so it doesn't really matter which way it faces as each way is essentially fresh air.
the reason I want to move it is that the fan on the titan onscures the 1st RAM slot thus stopping me from using that slot and also fron using the RAM cooler that came with the corsair RAM. I know opinion varies on the corsair RAM cooler, but what I really would like is advice re rotating the heat sink
All advice appreciated
