Cross Polarisation
15 Mar 2005
Tried my hand at this technique.
Comments Welcomed
The set up i used here was quite primitve so i couldnt get any better shots.
Yuo acheive this by using two polarisors.
I used a Cokin P Linear polarisor on the lgiht source ( a very small Desklamp) Which was under a glass table.
I then used a cir Pol on the lens.
If you turn the cir pol you will get different effects and the bg changes form black to white. I had to always have it on the black BG because otherwise you would see the desklamp and it would look distracting.
