Crossfire 2 qustion
Suspended
23 Oct 2003
Cambridge
if im running a x1950pro 256, and add a 512version and make sure thats in slot 1, will it use 512ram or 256?
tia
Foxor-
it will then use a total of 768MB as it should be using the memory from both of them.
Afraid thats wrong, when 2x cards are Crossfired or SLI'd, you lose 1x of your cards memory, when 2x are paired, but 1x card has less memory than the other, then it defaults to the lowest amount, so he will get 256mb, or i may be wrong there and he may get the memory from whatever card he has in the primary slot, i can't remember, but i know you definately lose 1x cards memory either way. :p
