4850-4850 vs 4850-4870
Hello,
I've read somewhere (probably a credible source
) that the way Crossfire and SLI work are slightly different, where cards in SLI mode have to be performing identically even if they have different specs. For example, "SLI'ing" a 260 and a 280 would make 280 perform at a 260 level because there needs to be a 1:1 sync (260 one frame, 280 the next). Crossfire, OTOH, does it such that if a 4850 and a 4870 are "Crossfire'd" they would do their fair share of work, as lets say if there was a 25% performance advantage for the 4870 over the 4850, it would do that much more work. (splitting the screen in 40-60 for example?)
The common concensus around the forums, however, is that 4850-4870CF would perform indentically to 4850-4850CF.
Is this substantial?
Cheers
Hello,
) that the way Crossfire and SLI work are slightly different, where cards in SLI mode have to be performing identically even if they have different specs. For example, "SLI'ing" a 260 and a 280 would make 280 perform at a 260 level because there needs to be a 1:1 sync (260 one frame, 280 the next). Crossfire, OTOH, does it such that if a 4850 and a 4870 are "Crossfire'd" they would do their fair share of work, as lets say if there was a 25% performance advantage for the 4870 over the 4850, it would do that much more work. (splitting the screen in 40-60 for example?)The common concensus around the forums, however, is that 4850-4870CF would perform indentically to 4850-4850CF.
Cheers
