Crossfire ASUS 7970 Direct CU2 with Gigabyte Z87-D3HP
25 Mar 2004
Fareham
Considering getting another ASUS 7970 Direct CU2 for my board to run in Crossfire.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-273-AS
I know that the second PCI-E slot on the Gigabyte Z87-D3HP is limited to 4x, and the ASUS 7970 CU2 cards are 3 slot models, so wanted some opinions from people before I went ahead and do it. Is the spacing going to be a problem here?
I am gaming at 2560 * 1440 so I need some horse power, and I figure a second 7970 in Crossfire would keep me going for hopefully around 3 years or so before I even needed to consider upgrading my Graphics again.
Shame I missed the deal the other day with the 7950's as two of those in Crossfire would have worked out only £100 more than one of these 7970's. I can still return the 7970 I have under DSR if I had to but ultimately would rather not unless I'm making savings elsewhere.
I am running the i7 4770K Haswell processor so that should be fine for Crossfire either way.
You're not going to have any space between the two cards, so heat will be a problem. You could crossfire with a different 7970, i.e. a 2 slot card.
Running at 8x4x isn't going to be a serious issue with PCI-E 3.0.
This is quite common though, obviously not ideal but a lot of people do it..
Two three slot cards aren't all that common. The 7970s overclocked will put out quite a bit of heat. But if you don't overclock you may as well go for 2x7950s (rear exhaust) and overclock those for the same performance as stock 2x7970s.
I'm not entirely keen on running 2 different cards here really, if it came to that it was a bad idea I would rather send the 7970 back and get two 7950's instead that were identical from the off.
For me low noise is important, so I wouldn't want to crossfire two noisy cards. The 7970 so far seems reasonably quiet to me.
The 7950's at £160 the other day were a steal, wonder if we would see any more deals like that for them, the HIS ones are back up to £185 now which makes them less attractive as an alternative.
There's no harm in running different cards. If you want to run two Asus 7970s you'll need a spacious case and very good air flow (something like the Corsair Carbide 540).
The HIS cards are pretty quiet, and have no real issue with temps.
I've got the Z87X-D3H with 2 HIS 7950s and they fit but I have no spare PCI-E slots. Although the K2 cooler blocks off the top one so if I had a smaller CPU cooler I would have a spare slot.
The fact these cards exhaust heat was the main reason I got them - makes them ideal for crossfire. I paid £190 each for them and considered them a very good buy. After I sold off all the games I think the true cost was £260.
Thanks, to save the hassle I am thinking just getting another ASUS 7970 CU2 would be OK, I am not planning to massively overclock them or anything so I don't think I would be getting too high temps.
I know I can get other 7970's to mix and match, but the next cheapest ones are more expensive by £30 or so so I would effectively be paying that to get a bigger gap between the cards.
It's a reasonable case, Corsair 650D. I don't use any other PCI slots, it has a large case fan on the top extracting, with another large one at the front for the intake. I don't perceive heat to be a massive issue hopefully!
