Good evening,
Ok well another one of my moaning threads about a similar issue but here goes;
I have just been looking at my machine in CPUZ in crossfire is it normal for one card to have a different memory/core also for some reason does not show the pci-e version it is running at, just a tad concerned it is running at a lower spec than it should be or my mobo is bottlenecking it.
I have a Asus p6t deluxe with 2x 5870 in the pci-e 16x slots
card #1 shows 849mhz core 1200Mhz memory
card #2 shows 156mhz core 418Mhz memory
I just feel something is not right with my setup every game I get is giving me crap results reguardless of what driver I use, I know xfire is rather buggy but all the games I have played the only one that works properly is Batman AA.
I know Crysis2 is buggy but I get unplayable fps with it unless i change it to high performance even so it is better with one card.
Blackops isn't exactly as 100% as it should be still slightly laggy here and there. it just feels as though my system is struggling.
Do I need to change my motherboard?
Also sometimes at boot my cards/card goes at full fan speed, I then have to turn the machine off for 5mins or so and then it works fine again - I have tried the swapping the cards around but always seems to be the top one which the fan speeds at full on, when this happens I get no video output.
Specs are as follows;
Asus p6t
i7 920 d0
12gb DDR3 Tripple Channel
2x 5870 in eyefinity with 3x 22" @5760x1080 60hz
850w PSU
Thanks in advance.
Asus p6t
i7 920 d0
850w PSU
Thanks in advance.
