I have had many people ask me how to make sure AMD crossfire is working in star citizen follow these steps to make sure you have it running.
1 Download drivers = radeon 16.1.1 or newer
2 Install
3 Right click desktop and launch AMD radeon settings
4 Click gaming tab in next window
5 Select the star citizen exe left click or manaully add it if it is not there
6 Set AMD crossfire mode to Amd predefined
7 Search bar will appear type in ryse
8 Select ryse son of rome as profile to be used (same engine ish)
9 Close radeon settings
10 Open radeon settings and select preferences then select radeon additional settings
11 In radeon additional settings select gaming then amd crossfire make sure crossfire is enabled and the tick box that says show amd crossfire icon where applicable is ticked
12 Make sure the game runs fullscreen not windowed
13 Launch star citizen you should now see a amd crossfire status icon showing the game is running in multi gfx mode enjoy the fps
Thank you and I hope this helped any questions just post and ill try n help
2 Install
