crossfire help pls
3 Jan 2006
Ok just installed my second card 2 x 1950pro 7.12 drivers both bridges are attached and power is going to both cards, ive enabled crossfire in the ati tool tray and even turned off the A.I setting as any 3d program turned into a blur. So at least now I can see crysis but there is no gain in frames per second its like the cards are not working in crossfire. I get a drop in frame rates:confused: Im using the cryis benchmark tool for this test.
My rig
E6600 @ 3GHZ
P35 DS4
2GB OCZ
520W POWER SUPPLY
Is there any one who can help me?
Crysis has not been optimised yet for Crossfire this will come in the first crysis patch. However you do get FPS improvements with 7.12 with crossfire running as opposed to it not running. It works especially well on the first couple of levels in the game. So the answer is yes it does work with Crossfire but is by no means using the benefits of Crossfire to full potential.
It doesn't officially support crossfire as yet. Try another game that it does work with try it out :)
You can get it to work btw, just needs some fiddling.
Matthew
I would actually suggest you sell both those 1950 pro's and get yourself a single 3850 512 with the money you got for the cards :)
Be less hassle and a vast improvement over the pros :)
Matthew
