Crossfire: How do I overclock more?
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
I've got the slider push to max in the CC panel and I want more.
Got latest version of ATI tool, when it loads it says it needs to close a system process, some ATI thing that changes 2D/3D speeds so I say yes to remove this.
It loads and detects the 2D clock speeds.
When I try to set core above 650MHz it crashes, yet the core is at 700MHz with Overdrive CC panel and that runs fine.
Are there any other overclocking utilities I can or is this a known problem? Any fixes as I'd suspect these cards will get close to 750 core and over 1600 memory....
Think the problem is the 2d speeds use a lower core voltage so you need to set that to 3d voltage, or more :eek: ,also before upping the core speed. Don't aske me what the voltage needs to be set to though for 3d speeds :confused: im sure some one more knowledgable in these things will be along soon :D
