Crossfire Problem
3 Nov 2003
Southampton
Got my 2nd 5870 yesterday and I have a problem with the 2nd gpu not clocking down on idle.
Anyone seen this before?
Is there an easy fix for this or is it normal? :confused:
Thanks.
Thanks.
There is a bug with 10.12 drivers with multi GPU downclocking 10.12a may not have this problem.
Tried both and exactly the same.
CCC for my 2nd card is blank temp = 0C clocks = 0 unless I load up GPU Z then CCC will show some values for a min then back to 000.
I seem to remember my 5870 xfire setup having the same issue
As I understood it only the primary card would down clock, the secondary card would always stay at default / clocked clocks
