crossfire problems pls help?
10 Sep 2008
Uk
hi i have 2 HIS HD 7950 IceQ BOOST 3GB setup in my pc.. i have just recently bought the 2nd one just to try crossfire out.. now when i have just one card enabled i never have any problems but the second i enable crossfire mode..any game a load up (except one) stays on for 3-10 seconds then freezes my pc and i have to keep hold of the power button to be able to boot again (also this sometimes stops my drive from booting until i restore defaults in the BIOS) i have swapped the cards around and also tried changing the crossfire bridge but still the same problems ..my psu i'm using is a corsair TX 750w.. this has been happening with new and old drivers as i was trying a few things out myself.. i did a stress test on the gpu's using furmark as 3dmark kept freezing also.. and the temps went from 39% (idle) up to 85% and stayed there with no problems at all :/ i have also done a memtest which is also without errors..
i have no idea what else to try.. my mind is at a loss.. also here is my Dxdiag
any help at all would be very much appreciated :)
Code:
System Information
      Time of this report: 3/31/2017, 01:33:15
             Machine name: DESKTOP-OI790P9
               Machine Id: {7979855F-70ED-4518-B464-4EB44748F57D}
         Operating System: Windows 10 Pro 64-bit (10.0, Build 14393) (14393.rs1_release_inmarket.170303-1614)
                 Language: English (Regional Setting: English)
      System Manufacturer: System manufacturer
             System Model: System Product Name
                     BIOS: 2303
                Processor: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz (8 CPUs), ~3.5GHz
                   Memory: 16384MB RAM
      Available OS Memory: 16328MB RAM
                Page File: 2257MB used, 16503MB available
              Windows Dir: C:\Windows
          DirectX Version: DirectX 12
      DX Setup Parameters: Not found
         User DPI Setting: Using System DPI
       System DPI Setting: 144 DPI (150 percent)
          DWM DPI Scaling: UnKnown
                 Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
           DxDiag Version: 10.00.14393.0000 64bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
        Sound Tab 3: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: AMD Radeon HD 7900 Series
       Manufacturer: Advanced Micro Devices, Inc.
          Chip type: AMD Radeon Graphics Processor (0x679A)
           DAC type: Internal DAC(400MHz)
        Device Type: Full Device
         Device Key: Enum\PCI\VEN_1002&DEV_679A&SUBSYS_201C1787&REV_00
      Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
     Display Memory: 11217 MB
   Dedicated Memory: 3052 MB
      Shared Memory: 8164 MB
       Current Mode: 1920 x 1080 (32 bit) (59Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: LG TV
         Monitor Id: GSM0001
        Native Mode: 1920 x 1080(p) (60.000Hz)
        Output Type: HDMI
        Driver Name: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\aticfx64.dll,C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\aticfx64.dll,C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\aticfx64.dll,C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdxc64.dll
Driver File Version: 21.19.0519.0002 (English)
     Driver Version: 21.19.519.2
        DDI Version: 12
     Feature Levels: 11_1,11_0,10_1,10_0,9_3,9_2,9_1
       Driver Model: WDDM 2.1
Graphics Preemption: DMA
 Compute Preemption: DMA
           Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
     Power P-states: Not Supported
  Driver Attributes: Final Retail
   Driver Date/Size: 10/02/2017 01:00:00, 1589880 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp: Unknown
  Device Identifier: {D7B71EE2-24DA-11CF-3574-1B02BCC2D835}
          Vendor ID: 0x1002
          Device ID: 0x679A
          SubSys ID: 0x201C1787
        Revision ID: 0x0000
 Driver Strong Name: oem8.inf:cb0ae41469197015:ati2mtag_R575DS:21.19.519.2:pci\ven_1002&dev_679a
     Rank Of Driver: 00D12001
        Video Accel: ModeMPEG2_A ModeMPEG2_C
        DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeMPEG2_IDCT  DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT  DXVA2_ModeH264_VLD_Stereo_NoFGT  DXVA2_ModeVC1_VLD  DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC
   Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
       D3D9 Overlay: Not Supported
            DXVA-HD: Not Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
           MPO Caps: Not Supported
        MPO Stretch: Not Supported
    MPO Media Hints: Not Supported
        MPO Formats: Not Supported
Sound Devices
            Description: Speakers (Realtek High Definition Audio)
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0887&SUBSYS_10438445&REV_1003
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: RTKVHD64.sys
         Driver Version: 6.00.0001.7910 (English)
            WHQL Logo'd: Yes
          Date and Size: 16/08/2016 00:00:00, 5276168 bytes
            Other Files:
        Driver Provider: Realtek Semiconductor Corp.
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
            Description: Realtek Digital Output (Realtek High Definition Audio)
 Default Sound Playback: No
 Default Voice Playback: No
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            WHQL Logo'd: Yes
            Other Files:
              Cap Flags: 0xF1F
              HW Memory: 0
            Description: 1 - LG TV (AMD High Definition Audio Device)
            Hardware ID: HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1003
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: AtihdWT6.sys
         Driver Version: 10.00.0001.0001 (English)
            WHQL Logo'd: Yes
          Date and Size: 30/11/2016 00:00:00, 101376 bytes
            Other Files:
        Driver Provider: Advanced Micro Devices
              Cap Flags: 0xF1F
              HW Memory: 0
Sound Capture Devices
Video Capture Devices
Number of Devices: 0
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: USB Mouse
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x1EA7, 0x0011
        FF Driver: n/a
      Device Name: SI Gaming Keyboard
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x0C45, 0x8603
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x1E26
| Matching Device ID: USB\ROOT_HUB20
| Service: usbhub
| Driver: usbhub.sys, 7/16/2016 12:41:55, 501088 bytes
| Driver: usbd.sys, 7/16/2016 12:41:55, 32608 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: USB\Class_09
| | Service: usbhub
| +-+ USB Composite Device
| | | Matching Device ID: USB\COMPOSITE
| | | Service: usbccgp
| | | Driver: usbccgp.sys, 7/16/2016 12:41:55, 169312 bytes
| | +-+ USB Input Device
| | | | Matching Device ID: USB\Class_03&SubClass_01
| | | | Service: HidUsb
| | | | Driver: hidusb.sys, 11/22/2016 23:55:43, 38400 bytes
| | | | Driver: hidclass.sys, 11/22/2016 23:55:43, 156672 bytes
| | | | Driver: hidparse.sys, 11/22/2016 23:55:43, 40960 bytes
| | | +-+ HID Keyboard Device
| | | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | | Service: kbdhid
| | | | | Driver: kbdhid.sys, 11/22/2016 23:55:43, 39424 bytes
| | | | | Driver: kbdclass.sys, 7/16/2016 12:41:54, 62304 bytes
+ USB Root Hub (xHCI)
| Vendor/Product ID: 0x8086, 0x1E31
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 7/16/2016 12:41:55, 535904 bytes
| | Service: usbccgp
| | | Service: HidUsb
| | +-+ HID-compliant mouse
| | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 7/16/2016 12:41:54, 32256 bytes
| | | | Driver: mouclass.sys, 7/16/2016 12:41:54, 59232 bytes
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 186.1 GB
Total Space: 237.9 GB
File System: NTFS
      Model: Samsung SSD 840 EVO 250GB
      Drive: D:
 Free Space: 54.7 GB
Total Space: 1907.6 GB
File System: NTFS
      Model: WDC WD20EARS-00MVWB0
      Drive: E:
 Free Space: 1.6 GB
Total Space: 1907.7 GB
File System: NTFS
      Model: ST2000DM001-9YN164
      Drive: F:
 Free Space: 15.0 GB
Total Space: 953.9 GB
File System: NTFS
      Model: WDC WD10EADS-00M2B0
      Drive: G:
 Free Space: 809.9 GB
File System: NTFS
      Model: SEAGATE ST31000340NS
      Drive: H:
 Free Space: 547.8 GB
File System: NTFS
      Model: TOSHIBA DT01ACA100
      Drive: I:
      Model: hp DVD RW AD-7561S USB Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 10.00.14393.0000 (English), 7/16/2016 12:41:53, 173056 bytes
System Devices
Device ID: PCI\VEN_8086&DEV_0151&SUBSYS_84CA1043&REV_09\3&11583659&0&08
   Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.14393.0594 (English), 12/14/2016 06:18:10, 335712 bytes
     Name: Standard SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_1E02&SUBSYS_84CA1043&REV_04\3&11583659&0&FA
   Driver: C:\Windows\system32\DRIVERS\storahci.sys, 10.00.14393.0953 (English), 3/4/2017 08:08:59, 130912 bytes
     Name: High Definition Audio Bus
Device ID: PCI\VEN_1002&DEV_AAA0&SUBSYS_AAA01787&REV_00\4&20BDBE28&0&01E0
   Driver: C:\Windows\system32\DRIVERS\amdkmafd.sys, 8.14.0001.6003 (English), 8/18/2016 13:41:28, 49448 bytes
   Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 10.00.14393.0000 (English), 7/16/2016 12:41:52, 83456 bytes
   Driver: C:\Windows\system32\DRIVERS\drmk.sys, 10.00.14393.0000 (English), 7/16/2016 12:41:52, 97280 bytes
   Driver: C:\Windows\system32\DRIVERS\portcls.sys, 10.00.14393.0000 (English), 7/16/2016 12:41:52, 366592 bytes
     Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_85051043&REV_09\4&11EB9DBD&0&00E4
   Driver: C:\Windows\system32\DRIVERS\rt640x64.sys, 9.01.0404.2015 (English), 7/16/2016 12:41:53, 589824 bytes
     Name: LPC Controller
Device ID: PCI\VEN_8086&DEV_1E44&SUBSYS_84CA1043&REV_04\3&11583659&0&F8
   Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.14393.0000 (English), 7/16/2016 12:41:53, 18784 bytes
     Name: SM Bus Controller
Device ID: PCI\VEN_8086&DEV_1E22&SUBSYS_84CA1043&REV_04\3&11583659&0&FB
   Driver: n/a
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_84CA1043&REV_C4\3&11583659&0&E5
Device ID: PCI\VEN_8086&DEV_1E18&SUBSYS_84CA1043&REV_C4\3&11583659&0&E4
Device ID: PCI\VEN_8086&DEV_1E10&SUBSYS_84CA1043&REV_C4\3&11583659&0&E0
Device ID: PCI\VEN_1B21&DEV_1080&SUBSYS_84891043&REV_03\4&17F33A27&0&00E5
     Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_1E3A&SUBSYS_84CA1043&REV_04\3&11583659&0&B0
   Driver: C:\Windows\system32\DRIVERS\TeeDriverW8x64.sys, 11.00.0005.1189 (English), 4/4/2016 10:06:10, 195152 bytes
     Name: Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
Device ID: PCI\VEN_8086&DEV_1E31&SUBSYS_84CA1043&REV_04\3&11583659&0&A0
   Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 10.00.14393.0000 (English), 7/16/2016 12:41:55, 381792 bytes
     Name: AMD Radeon HD 7900 Series
Device ID: PCI\VEN_1002&DEV_679A&SUBSYS_201C1787&REV_00\4&BAB4994&0&0008
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atio6axx.dll, 21.19.0519.0002 (English), 2/20/2017 12:44:20, 32347544 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atioglxx.dll, 21.19.0519.0002 (English), 2/20/2017 12:44:32, 26357144 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atidxx32.dll, 21.19.0519.0002 (English), 2/20/2017 12:39:12, 9789120 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atidxx64.dll, 21.19.0519.0002 (English), 2/20/2017 12:39:18, 12024664 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\ATIODCLI.exe, 21.19.0519.0002 (English), 2/20/2017 12:44:22, 76184 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\ATIODE.exe, 21.19.0519.0002 (English), 2/20/2017 12:44:28, 357784 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\aticalcl.dll, 21.19.0519.0002 (English), 2/20/2017 12:43:20, 74136 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\aticalcl64.dll, 21.19.0519.0002 (English), 2/20/2017 12:43:22, 80792 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\aticaldd.dll, 21.19.0519.0002 (English), 2/20/2017 12:43:22, 14327704 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\aticaldd64.dll, 21.19.0519.0002 (English), 2/20/2017 12:43:24, 15736728 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\aticalrt.dll, 21.19.0519.0002 (English), 2/20/2017 12:43:28, 77208 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\aticalrt64.dll, 21.19.0519.0002 (English), 2/20/2017 12:43:30, 87448 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atig6pxx.dll, 21.19.0519.0002 (English), 2/20/2017 12:44:04, 131480 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atig6txx.dll, 21.19.0519.0002 (English), 2/20/2017 12:44:10, 211864 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atigktxx.dll, 21.19.0519.0002 (English), 2/20/2017 12:44:14, 185240 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atiglpxx.dll, 21.19.0519.0002 (English), 2/20/2017 12:44:16, 116120 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atikmpag.sys, 21.19.0519.0002 (English), 2/20/2017 12:44:18, 525208 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atiu9p64.dll, 21.19.0519.0002 (English), 2/20/2017 12:39:34, 161296 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atiu9pag.dll, 21.19.0519.0002 (English), 2/20/2017 12:39:38, 134312 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atiuxp64.dll, 21.19.0519.0002 (English), 2/20/2017 12:39:58, 180424 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atiuxpag.dll, 21.19.0519.0002 (English), 2/20/2017 12:39:58, 149856 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\coinst_16.60.dll, 1.00.0005.0009 (English), 2/20/2017 12:44:58, 924056 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\aticfx32.dll, 21.19.0519.0002 (English), 2/20/2017 12:39:06, 1305736 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\aticfx64.dll, 21.19.0519.0002 (English), 2/20/2017 12:39:08, 1589880 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdocl.dll, 21.19.0519.0002 (English), 2/20/2017 12:41:34, 46401432 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdocl64.dll, 21.19.0519.0002 (English), 2/20/2017 12:41:48, 59111320 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdhdl32.dll, 2/20/2017 12:39:48, 189336 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdhdl64.dll, 2/20/2017 12:39:56, 209304 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdmantle32.dll, 21.19.0519.0002 (English), 2/20/2017 12:40:40, 7537048 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdmantle64.dll, 21.19.0519.0002 (English), 2/20/2017 12:40:46, 9584024 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\ativce03.dat, 2/20/2017 06:05:30, 160768 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\ativvaxy_vi.dat, 2/20/2017 06:05:32, 325316 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\ativvaxy_vi_nd.dat, 2/20/2017 06:05:32, 325056 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\ativvaxy_cz_nd.dat, 2/20/2017 06:05:30, 271456 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amde31a.dat, 2/20/2017 06:05:04, 159072 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\ativvaxy_FJ.dat, 2/20/2017 06:05:30, 266772 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\ativvaxy_FJ_nd.dat, 2/20/2017 06:05:30, 266512 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdxc32.dll, 21.19.0519.0002 (English), 2/20/2017 12:38:58, 9818600 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdxc64.dll, 21.19.0519.0002 (English), 2/20/2017 12:39:00, 12325224 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\RapidFireServer.dll, 1.01.0000.0019 (English), 2/20/2017 12:46:00, 42392 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\RapidFireServer64.dll, 1.01.0000.0019 (English), 2/20/2017 12:46:04, 44952 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\Rapidfire.dll, 1.01.0000.0022 (English), 2/20/2017 12:45:52, 478104 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\Rapidfire64.dll, 1.01.0000.0022 (English), 2/20/2017 12:45:56, 546712 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdocl12cl.dll, 21.19.0519.0002 (English), 2/20/2017 12:41:38, 22666136 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdocl12cl64.dll, 21.19.0519.0002 (English), 2/20/2017 12:41:42, 28664720 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdicdxx.dat, 2/20/2017 06:05:06, 925635 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atiicdxx.dat, 2/20/2017 06:05:28, 737410 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\ativvaxy_el_nd.dat, 2/20/2017 06:05:30, 368832 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amde34a.dat, 2/20/2017 06:05:06, 166560 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\ativvaxy_stn_nd.dat, 2/20/2017 06:05:32, 276832 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amde34b.dat, 2/20/2017 06:05:06, 166560 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdoclvp9lib32.dll, 2/20/2017 12:41:54, 2299288 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdoclvp9lib64.dll, 2/20/2017 12:41:58, 2388888 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amduve32.dll, 14.00.0006.0000 (English), 2/20/2017 12:42:04, 143256 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amduve64.dll, 14.00.0006.0000 (English), 2/20/2017 12:42:08, 163736 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdave32.dll, 21.19.0519.0002 (English), 2/20/2017 12:38:28, 112960 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdave64.dll, 21.19.0519.0002 (English), 2/20/2017 12:38:30, 124920 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdmmcl.dll, 21.19.0519.0002 (English), 2/20/2017 12:41:22, 63384 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\amdmmcl6.dll, 21.19.0519.0002 (English), 2/20/2017 12:41:28, 75672 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atikmdag.sys, 21.19.0519.0002 (English), 2/20/2017 12:44:18, 32699288 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atitmm64.dll, 21.19.0519.0002 (English), 2/20/2017 12:44:40, 295320 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atiumd64.dll, 21.19.0519.0002 (English), 2/20/2017 12:39:44, 9444800 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atiumd6a.dll, 21.19.0519.0002 (English), 2/20/2017 12:39:50, 12492120 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atiumdag.dll, 21.19.0519.0002 (English), 2/20/2017 12:39:52, 7684192 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\atiumdva.dll, 21.19.0519.0002 (English), 2/20/2017 12:39:58, 11441744 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\ativce02.dat, 2/20/2017 06:05:30, 100816 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\ativvaxy_cik.dat, 2/20/2017 06:05:30, 234292 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\c0311199.inf_amd64_71ef621a77f87d8c\ativvaxy_cik_nd.dat, 2/20/2017 06:05:30, 234032 bytes
   Driver: C:\Windows\system32\atieclxx.exe, 21.19.0519.0002 (English), 2/20/2017 12:43:58, 535960 bytes
   Driver: C:\Windows\system32\atiesrxx.exe, 21.19.0519.0002 (English), 2/20/2017 12:44:00, 298904 bytes
   Driver: C:\Windows\system32\atidemgy.dll, 4.05.6250.15489 (English), 2/20/2017 12:43:38, 467352 bytes
   Driver: C:\Windows\system32\ati2erec.dll, 21.19.0519.0002 (English), 2/20/2017 12:43:10, 68504 bytes
   Driver: C:\Windows\system32\atig6txx.dll, 21.19.0519.0002 (English), 2/20/2017 12:44:10, 211864 bytes
   Driver: C:\Windows\system32\atiapfxx.blb, 2/20/2017 06:05:26, 782216 bytes
   Driver: C:\Windows\system32\OpenCL.dll, 21.19.0519.0002 (English), 2/20/2017 12:42:42, 121240 bytes
   Driver: C:\Windows\system32\clinfo.exe, 2/20/2017 12:44:48, 277912 bytes
   Driver: C:\Windows\system32\amdhcp64.dll, 21.19.0519.0002 (English), 2/20/2017 12:38:50, 151448 bytes
   Driver: C:\Windows\system32\hsa-thunk64.dll, 2/20/2017 12:45:30, 276376 bytes
   Driver: C:\Windows\system32\kapp_ci.sbin, 2/20/2017 06:05:34, 120880 bytes
   Driver: C:\Windows\system32\kapp_si.sbin, 2/20/2017 06:05:34, 114704 bytes
   Driver: C:\Windows\system32\samu_krnl_ci.sbin, 2/20/2017 06:05:34, 154384 bytes
   Driver: C:\Windows\system32\samu_krnl_isv_ci.sbin, 12/12/2013 09:53:56, 138832 bytes
   Driver: C:\Windows\system32\mantle64.dll, 21.19.0519.0002 (English), 2/20/2017 12:45:36, 169368 bytes
   Driver: C:\Windows\system32\mantleaxl64.dll, 21.19.0519.0002 (English), 2/20/2017 12:45:40, 138136 bytes
   Driver: C:\Windows\system32\amdgfxinfo64.dll, 2/20/2017 12:39:42, 256920 bytes
   Driver: C:\Windows\system32\atieah64.exe, 2/20/2017 12:43:54, 239000 bytes
   Driver: C:\Windows\system32\detoured.dll, 21.19.0519.0002 (English), 2/20/2017 12:45:04, 29080 bytes
   Driver: C:\Windows\system32\amdlvr64.dll, 1.00.0010.0000 (English), 2/20/2017 12:40:36, 891800 bytes
   Driver: C:\Windows\system32\amdvlk64.dll, 1.00.0037.0000 (English), 2/20/2017 12:42:20, 9880984 bytes
   Driver: C:\Windows\system32\amd-vulkan64.json, 2/20/2017 06:05:04, 144 bytes
   Driver: C:\Windows\system32\GameManager64.dll, 2/20/2017 12:45:22, 284056 bytes
   Driver: C:\Windows\system32\amdmiracast.dll, 2/20/2017 12:38:50, 474984 bytes
   Driver: C:\Windows\system32\dgtrayicon.exe, 2/20/2017 12:45:06, 290712 bytes
   Driver: C:\Windows\system32\AMDKernelEvents.man, 2/20/2017 06:05:06, 20580 bytes
   Driver: C:\Windows\system32\amfrt64.dll, 1.04.0001.0000 (English), 2/20/2017 12:43:04, 2504088 bytes
   Driver: C:\Windows\system32\amdmcl64.dll, 1.06.0000.0000 (English), 2/20/2017 12:41:00, 91544 bytes
   Driver: C:\Windows\system32\amdave64.dll, 21.19.0519.0002 (English), 2/20/2017 12:38:30, 124920 bytes
   Driver: C:\Windows\system32\amdpcom64.dll, 21.19.0519.0002 (English), 2/20/2017 12:38:54, 119736 bytes
   Driver: C:\Windows\system32\atiadlxx.dll, 21.19.0519.0002 (English), 2/20/2017 12:43:10, 1261976 bytes
   Driver: C:\Windows\system32\atiapfxx.exe, 21.19.0519.0002 (English), 2/20/2017 12:43:18, 411032 bytes
   Driver: C:\Windows\system32\aticfx64.dll, 8.17.0010.1513 (English), 2/20/2017 12:43:36, 149504 bytes
   Driver: C:\Windows\system32\atidxx64.dll, 2/20/2017 12:43:44, 110488 bytes
   Driver: C:\Windows\system32\atimpc64.dll, 21.19.0519.0002 (English), 2/20/2017 12:39:28, 119736 bytes
   Driver: C:\Windows\system32\atimuixx.dll, 21.19.0519.0002 (English), 2/20/2017 12:44:20, 119192 bytes
   Driver: C:\Windows\system32\atisamu64.dll, 21.19.0519.0002 (English), 2/20/2017 12:44:36, 145304 bytes
   Driver: C:\Windows\system32\atiumd6a.cap, 2/20/2017 06:05:30, 3437632 bytes
   Driver: C:\Windows\system32\ativvsva.dat, 11/21/2016 17:49:28, 157144 bytes
   Driver: C:\Windows\system32\ativvsvl.dat, 11/21/2016 17:49:28, 204952 bytes
   Driver: C:\Windows\system32\amdxc64.dll, 8.18.0010.0161 (English), 2/20/2017 12:42:30, 108440 bytes
   Driver: C:\Windows\SysWOW64\atigktxx.dll, 21.19.0519.0002 (English), 2/20/2017 12:44:14, 185240 bytes
   Driver: C:\Windows\SysWOW64\atiapfxx.blb, 2/20/2017 06:05:26, 782216 bytes
   Driver: C:\Windows\SysWOW64\OpenCL.dll, 21.19.0519.0002 (English), 2/20/2017 12:42:36, 112024 bytes
   Driver: C:\Windows\SysWOW64\amdhcp32.dll, 21.19.0519.0002 (English), 2/20/2017 12:38:46, 135280 bytes
   Driver: C:\Windows\SysWOW64\hsa-thunk.dll, 2/20/2017 12:45:24, 242072 bytes
   Driver: C:\Windows\SysWOW64\mantle32.dll, 21.19.0519.0002 (English), 2/20/2017 12:45:34, 143768 bytes
   Driver: C:\Windows\SysWOW64\mantleaxl32.dll, 21.19.0519.0002 (English), 2/20/2017 12:45:38, 117656 bytes
   Driver: C:\Windows\SysWOW64\amdgfxinfo32.dll, 2/20/2017 12:39:38, 229784 bytes
   Driver: C:\Windows\SysWOW64\atieah32.exe, 2/20/2017 12:43:50, 216984 bytes
   Driver: C:\Windows\SysWOW64\detoured.dll, 21.19.0519.0002 (English), 2/20/2017 12:45:00, 29080 bytes
   Driver: C:\Windows\SysWOW64\amdlvr32.dll, 1.00.0010.0000 (English), 2/20/2017 12:40:30, 716184 bytes
   Driver: C:\Windows\SysWOW64\amdvlk32.dll, 1.00.0037.0000 (English), 2/20/2017 12:42:14, 7928216 bytes
   Driver: C:\Windows\SysWOW64\amd-vulkan32.json, 2/20/2017 06:05:04, 144 bytes
   Driver: C:\Windows\SysWOW64\GameManager32.dll, 2/20/2017 12:45:16, 248728 bytes
   Driver: C:\Windows\SysWOW64\amfrt32.dll, 1.04.0001.0000 (English), 2/20/2017 12:43:00, 2185624 bytes
   Driver: C:\Windows\SysWOW64\amdmcl32.dll, 1.06.0000.0000 (English), 2/20/2017 12:40:56, 75160 bytes
   Driver: C:\Windows\SysWOW64\amdave32.dll, 21.19.0519.0002 (English), 2/20/2017 12:38:28, 112960 bytes
   Driver: C:\Windows\SysWOW64\amdpcom32.dll, 21.19.0519.0002 (English), 2/20/2017 12:38:52, 102032 bytes
   Driver: C:\Windows\SysWOW64\atiadlxx.dll, 21.19.0519.0002 (English), 2/20/2017 12:43:14, 951192 bytes
   Driver: C:\Windows\SysWOW64\atiadlxy.dll, 21.19.0519.0002 (English), 2/20/2017 12:43:14, 951192 bytes
   Driver: C:\Windows\SysWOW64\aticfx32.dll, 8.17.0010.1513 (English), 2/20/2017 12:43:34, 145872 bytes
   Driver: C:\Windows\SysWOW64\atidxx32.dll, 2/20/2017 12:43:42, 98200 bytes
   Driver: C:\Windows\SysWOW64\atimpc32.dll, 21.19.0519.0002 (English), 2/20/2017 12:39:26, 102032 bytes
   Driver: C:\Windows\SysWOW64\atisamu32.dll, 21.19.0519.0002 (English), 2/20/2017 12:44:34, 126360 bytes
   Driver: C:\Windows\SysWOW64\atiumdva.cap, 2/20/2017 06:05:30, 3471376 bytes
   Driver: C:\Windows\SysWOW64\ativvsva.dat, 11/21/2016 17:49:28, 157144 bytes
   Driver: C:\Windows\SysWOW64\ativvsvl.dat, 11/21/2016 17:49:28, 204952 bytes
   Driver: C:\Windows\SysWOW64\amdxc32.dll, 8.18.0010.0161 (English), 2/20/2017 12:42:26, 96152 bytes
   Driver: C:\Program Files\AMD\amdkmpfd\amdkmpfd.stz, 16.60.6034.0000 (English), 2/20/2017 12:40:26, 86936 bytes
   Driver: C:\Program Files\AMD\amdkmpfd\amdkmpfd.itz, 2/20/2017 06:05:08, 1988 bytes
   Driver: C:\Program Files\AMD\amdkmpfd\amdkmpfd.ctz, 2/20/2017 06:05:06, 8162 bytes
   Driver: C:\Program Files\AMD\amdkmafd\amdkmafd.stz, 8.14.0001.6003 (English), 2/20/2017 12:40:10, 58168 bytes
   Driver: C:\Program Files\AMD\amdkmafd\amdkmafd.itz, 8/18/2016 11:41:26, 2126 bytes
   Driver: C:\Program Files\AMD\amdkmafd\amdkmafd.ctz, 8/18/2016 11:41:26, 10034 bytes
   Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\AMDh264Enc32.dll, 21.19.0519.0002 (English), 2/20/2017 12:38:34, 1092752 bytes
   Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\AMDh264Enc64.dll, 21.19.0519.0002 (English), 2/20/2017 12:38:36, 1289112 bytes
   Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\AMDhwDecoder_32.dll, 21.19.0519.0002 (English), 2/20/2017 12:40:00, 233368 bytes
   Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\AMDhwDecoder_64.dll, 21.19.0519.0002 (English), 2/20/2017 12:40:06, 271256 bytes
   Driver: C:\Windows\system32\coinst_16.60.dll, 1.00.0005.0009 (English), 2/20/2017 12:44:58, 924056 bytes
     Name: Memory Controller
Device ID: PCI\VEN_8086&DEV_0150&SUBSYS_84CA1043&REV_09\3&11583659&0&00
   Driver: n/a
     Name: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E26
Device ID: PCI\VEN_8086&DEV_1E26&SUBSYS_84CA1043&REV_04\3&11583659&0&E8
   Driver: C:\Windows\system32\drivers\usbehci.sys, 10.00.14393.0000 (English), 7/16/2016 12:41:55, 96096 bytes
   Driver: C:\Windows\system32\drivers\usbport.sys, 10.00.14393.0000 (English), 7/16/2016 12:41:55, 455520 bytes
   Driver: C:\Windows\system32\drivers\usbhub.sys, 10.00.14393.0000 (English), 7/16/2016 12:41:55, 501088 bytes
Device ID: PCI\VEN_1002&DEV_679A&SUBSYS_201C1787&REV_00\4&20BDBE28&0&00E0
Device ID: PCI\VEN_1002&DEV_AAA0&SUBSYS_AAA01787&REV_00\4&BAB4994&0&0108
     Name: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E2D
Device ID: PCI\VEN_8086&DEV_1E2D&SUBSYS_84CA1043&REV_04\3&11583659&0&D0
     Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_1E20&SUBSYS_84451043&REV_04\3&11583659&0&D8
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.14393.0000
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.14393.0000
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.14393.0000
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.14393.0000
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.14393.0000
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.14393.0000
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.14393.0953
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.14393.0000
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.14393.0000
DV Muxer,0x00400000,0,0,qdv.dll,10.00.14393.0000
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.14393.0953
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.14393.0000
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.14393.0953
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.14393.0953
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.14393.0206
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.14393.0953
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.14393.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.14393.0206
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.14393.0953
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.14393.0953
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.14393.0953
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.14393.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.14393.0000
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.14393.0000
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.14393.0206
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.14393.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.14393.0953
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.14393.0953
DV Splitter,0x00600000,1,2,qdv.dll,10.00.14393.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.14393.0953
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.14393.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.14393.0953
Video Renderer,0x00800001,1,0,quartz.dll,10.00.14393.0953
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.14393.0206
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.14393.0953
Video Renderer,0x00400000,1,0,quartz.dll,10.00.14393.0953
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.14393.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.14393.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.14393.0000
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.14393.0000
Overlay Mixer2,0x00200000,1,1,,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.14393.0000
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.14393.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.14393.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.14393.0000
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.14393.0206
Null Renderer,0x00200000,1,0,qedit.dll,10.00.14393.0206
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.14393.0000
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.14393.0206
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.14393.0206
Smart Tee,0x00200000,1,2,qcap.dll,10.00.14393.0000
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.14393.0953
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.14393.0953
Wave Parser,0x00400000,1,1,quartz.dll,10.00.14393.0953
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.14393.0953
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.14393.0953
File stream renderer,0x00400000,1,1,quartz.dll,10.00.14393.0953
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.14393.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.14393.0206
AVI Mux,0x00200000,1,0,qcap.dll,10.00.14393.0000
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.14393.0953
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.14393.0953
File Source (URL),0x00400000,0,1,quartz.dll,10.00.14393.0953
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.14393.0000
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.14393.0953
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.14393.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.14393.0953
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.14393.0000
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.14393.0000
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.14393.0000
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.14393.0000
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.14393.0000
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.14393.0953
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.14393.0000
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.14393.0000
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.14393.0953
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.14393.0953
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.14393.0953
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.14393.0953
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.14393.0953
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.14393.0953
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.14393.0351
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.14393.0351
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.14393.0351
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.14393.0953
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.14393.0953
WDM Streaming Capture Devices:
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.14393.0000
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.14393.0000
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,10.00.14393.0000
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,10.00.14393.0000
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.14393.0000
AMD HD Audio HDMI out #0,0x00200000,1,1,ksproxy.ax,10.00.14393.0000
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.14393.0000
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.14393.0000
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.14393.0000
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.14393.0000
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.14393.0000
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.14393.0000
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.14393.0000
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,10.00.14393.0351
Encrypt/Tag,0x00200000,0,0,EncDec.dll,10.00.14393.0351
PTFilter,0x00200000,0,0,EncDec.dll,10.00.14393.0351
XDS Codec,0x00200000,0,0,EncDec.dll,10.00.14393.0351
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.14393.0953
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.14393.0953
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.14393.0953
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.14393.0953
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.14393.0953
DirectSound: 1 - LG TV (AMD High Definition Audio Device),0x00200000,1,0,quartz.dll,10.00.14393.0953
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
  <transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
  AMD D3D11 Hardware MFT Playback Decoder, {17796AEB-0F66-4663-B8FB-99CBEE0224CE}, 0x4, 8, AMDhwDecoder_64.dll, 21.19.0519.0002
  Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.14393.0953
  DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.14393.0000
  Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}, 0x1, hevcdecoder.dll, 10.00.14393.0953
  Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.14393.0000
  Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.14393.0953
  WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.14393.0000
  WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.14393.0953
  MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.14393.0000
  Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.14393.0000
  Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}, 0x1, MSVP9DEC.dll, 10.00.14393.0953
  Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.14393.0000
Video Encoders:
  AMDh264Encoder, {ADC9BC80-0F41-46C6-AB75-D693D793597D}, 0x4, 8, AMDh264Enc64.dll, 21.19.0519.0002
  H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.14393.0000
  WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.14393.0000
  Microsoft MF VPX Encoder Transform, {AEB6C755-2546-4881-82CC-E15AE5EBFF3D}, 0x1, MSVPXENC.dll, 10.00.14393.0953
  H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.14393.0000
  WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.14393.0000
  Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.14393.0000
  H265 Encoder MFT, {F2F84074-8BCA-40BD-9159-E880F673DD3B}, 0x1, mfh265enc.dll, 10.00.14393.0000
Video Effects:
  Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.14393.0000
  Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.14393.0000
  VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.14393.0206
  Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.14393.0000
  Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.14393.0000
Video Processor:
  Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.14393.0351
Audio Decoders:
  Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.14393.0351
  MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.14393.0000
  WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.14393.0000
  Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.14393.0206
  A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.14393.0953
  GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.14393.0953
  WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.14393.0000
  Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.14393.0000
  Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.14393.0000
  Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.14393.0206
  WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.14393.0000
  G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.14393.0953
  IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.14393.0953
  MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.14393.0000
  Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.14393.0000
  ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.14393.0953
  Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.14393.0479
  DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.14393.0479
Audio Encoders:
  LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.14393.0479
  MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.14393.0953
  Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.14393.0000
  WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.14393.0000
  MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.14393.0000
  Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.14393.0000
  WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.14393.0000
  Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.14393.0000
  Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.14393.0000
  Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.14393.0206
Audio Effects:
  AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.14393.0000
  Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.14393.0000
Multiplexers:
  Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.14393.0953
Others:
  Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.14393.0953
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
httpnd:, {2EEEED04-0908-4CDB-AF8F-AC5B768A34C9}, Drm Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
{43564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{30395056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
{30385056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
{00001600-0000-0100-0800-000aa00389b71}, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket 127841588189, type 5
Event Name: WindowsUpdateFailure3
Response: Not available
Cab Id: 0
Problem signature:
P1: 10.0.14393.953
P2: 8024000b
P3: 56C931F5-E0A0-4FD8-B352-71273C3FC66B
P4: Download
P5: 1
P6: 0
P7: 0
P8: Update;taskhostw
P9: {855E8A7C-ECB4-4CA3-B045-1DFA50104289}
P10: 0
+++ WER1 +++:
Fault bucket , type 0
Cab Id: 0
Problem signature:
P1: 10.0.14393.953
P2: 8024000b
P4: Download
P5: 1
P6: 0
P7: 0
P10: 0
+++ WER2 +++:
Cab Id: 0
Problem signature:
P1: 10.0.14393.953
P2: 8024000b
P4: Download
P5: 1
P6: 0
P7: 0
P10: 0
+++ WER3 +++:
Fault bucket 127841598320, type 5
Cab Id: 0
Problem signature:
P1: 10.0.14393.953
P2: 8024000b
P3: 1456F2FD-3C71-4E81-A8EF-AB1B52F83F04
P4: Download
P5: 1
P6: 0
P7: 0
P10: 0
+++ WER4 +++:
Cab Id: 0
Problem signature:
P1: 10.0.14393.953
P2: 8024000b
P4: Download
P5: 1
P6: 0
P7: 0
P10: 0
+++ WER5 +++:
Cab Id: 0
Problem signature:
P1: 10.0.14393.953
P2: 8024000b
P4: Download
P5: 1
P6: 0
P7: 0
P10: 0
+++ WER6 +++:
Event Name: PnPDeviceProblemCode
Cab Id: 0
Problem signature:
P1: x64
P2: PCI\VEN_1002&DEV_AAA0&SUBSYS_AAA01787&REV_00
P3: {4d36e97d-e325-11ce-bfc1-08002be10318}
P4: 0000000A
P5: HDAudBus.sys
P6: 10.0.14393.0
P7: 07-16-2016
P8:
P9:
P10:
+++ WER7 +++:
Cab Id: 0
Problem signature:
P1: x64
P4: 0000000A
P5: HDAudBus.sys
P6: 10.0.14393.0
P7: 07-16-2016
P8:
P9:
P10:
+++ WER8 +++:
Fault bucket 133470505010, type 5
Event Name: MoAppCrash
Cab Id: 0
Problem signature:
P1: Microsoft.Windows.ShellExperienceHost_10.0.14393.953_neutral_neutral_cw5n1h2txyewy
P2: praid:App
P3: 10.0.14393.447
P4: 5819bf85
P5: StackHash12_38b
P6: 0.0.0.0
P7: 00000000
P8: 887a0020
P9: 0
P10:
+++ WER9 +++:
Event Name: PnPGenericDriverFound
Cab Id: 0
Problem signature:
P1: x64
P2: PCI\VEN_1002&DEV_679A&SUBSYS_201C1787&REV_00
P3:
P4:
P5:
P6:
P7:
P8:
P9:
P10:
Ahh, I missed the 750W buried in text - that should be enough as the cards are rated for ~180W each.
You've already checked for a bios update?
yea m8 i did a bios update too... i'm starting to wonder if it might be my mobo... see one card is in the 3.0 x16 slot and the other is in a 2.0 x4 slot.. maybe this could be my issue :/
I recently crossfire my 7950, I had problems too
my problem was it said my internal crossfire bridge was not connected properly, but there was nothing wrong
I solve my problem by
remove the bottom card, test the system see if the top card working properly
then switch the bottom card with the main card make sure than was working properly
then install that card that original top card in the bottom
everything was working after that,
weird but worked
i sort of did that at the beginning .. but i didn't try them one at time i just switched them around and turned crossfire off and both work perfectly on their own.. have u got 1 in a 3.0 x16 and one in a 2.0 x4 slot by any chance?
nah both in a x16 slot
on a asus prime pro mb with ryzen 1700
runs pretty nice, rise of tomb raider solid 60fps at 1080p
shame lack of vram can't go highest setting
ahh see that's really what i think my problem is the mobo.. it's the only thing that makes sense to me.. how is the new ryzen chip m8?
well I did try try 7950 crossfire before on a socket 775 mb, but didn't work
may be because I had too many expansion cards installed, wifi, usb3, tv card
may be not enough pcie lanes
the bottom card didn't register at all
ryzen is great, cpu load looks like its snoozing most of the time
part of my wonders should i just sell both 7950's and buy a single better card.. but i really wanna get this crossfire working haha.. i might just look for a new mobo atm that has 2 x16 pcie slots.. i'm also thinking of building an amd build next time.. deffo gonna go with one of them chips all the reviews look really good too :)
