I have just built a system with the following components;
Motherboard - Asus A8R32-MVP Deluxe
GFX card 1 - HIS X1900 ***Crossfire Edition*** 512MB
GFX card 2 - Connect3D ATI Radeon X1900 XT-X 512MB
CPU - AMD Athlon 64 X2 Dual Core 4800+
Memory - Mushkin 2GB DDR XP4000 Redline Extreme Performance Dual Channel Kit (2x1GB)
Power Supply - FSP Sparkle FX700-GLN Epsilon 700W ATX2.0 PSU
Hard Drives(2)Raid0 - Western Digital Raptor 150GB 10,000RPM SATA 16MB Cache RAID Bundle (BU-001-WD)
Case - CoolerMaster Stacker 830 RC-830 - Silver Trim
DVD drive - Plextor PX-760A 18x18 Dual Layer DVD±RW ReWriter
CPU fan - Zalman CNPS9500-LED Aero Flower (Socket 939/754/478/775) CPU Cooler
Monitor - Dell Ultrasharp 2405FPW 24" Widescreen LCD Monitor
OS - Microsoft Windows XP Professional Edition inc. SP2 - OEM
Installed windows, then updated it. Then installed catalyst 6.3 drivers.
Everything appeared to work ok. Then installed Everquest2, launched the game and noticed massive flickering. Disabled crossfire and the problem went away, re-enabled crossfire and the system rebooted itself.
I have installed other games, Doom3, Farcry etc and none work in crossfire mode, but work ok when crossfire is disabled (obviously only using one gfx card).
I have installed the cards in their correct slots, crossfire can be turned on and off through the catalyst control panel, but anything that starts to actually use crossfire mode is now crashing my computer, normally it reboots itself - sometimes it just freezes and I have to reset.
It looks to me as though one of two things has happened here, either I have received faulty goods, in which case I need to find out a way of discovering what is at fault, or I have been sold fully working equipment that doesn't do what it says on the box..
Any help would be much appreciated
