Crossfire Question
4 Dec 2002
Bourne, Lincs
Currently have a 1Gb 6870 in my machine and thinking about getting a 2nd for some Crossfire action.
Is Crossfire any good? Does it work with all games or do you need a specific profile for them etc?
Kimbie
Crossfire will give you around 80-95% extra fps in games that are supported / have profiles.
The good bit is the increase in fps.
The bad bits are :
Micro-stuttering, which you might or might not notice.
Newly released games not always supporting crossfire out-the-box & needing to wait on a profile from AMD, which can take a while at times.
Negative crossfire scaling, where you get lower fps with 2 cards than with one. This doesn't happen too often though.
List the games you're playing atm so others can give feedback on how well they work with crossfire, as quite a few here run 2 x AMD cards.
And make sure your PSU is at least 600w as well, depending on other componets, cpu overclock, etc...
^ +1
with a 1GB card you are going to be a bit limited to how much extra oomph another GPU can give you
in games where you aren't VRAM limited, 6870 crossfire should run better than say a 7870 or even a 7950, however at maximum settings, something like Battlefield 3 will burst that limit and you'll get really bad stuttering and FPS dips
I would look to sell the 6870 and get a newer, bigger VRAM single card personally
