crossfire r9 290 watercooled
28 Nov 2004
just wondering would it be ok to run my crossfire r9 290 oc watercooled max core voltage and aux voltage and power limit running max. temps never go over 50c. thanks in response.,
Why do you need to?
If it doesn't go over 50c then it's fine, but why do you need to run max voltage? Generally you don't need huge volts unless you are going for absolutely insane clocks (which shouldn't be ran 24/7 anyway).
Why do you need to?
Because to go 1175gpu 1400memory i need +60 on gpu voltage
