- 26 Sep 2013
- West End, Southampton
Hi guys.
I'm just looking for a little clarification on what's safe and what is not regarding the setup I'm running 24/7 on my cards.
Basically I'm very happy now with my setup, had some initial crashing and freezing issues but had to up the voltage on the cores to stop that which in turn has obviously increased my temps a wee bit. So would you say these stats are ok to run with or should I be a little concerned. I'm running 1125/1550 on my Crossfire setup with 1.225v, +20 power and temps on the cards are GPU1 68oC and GPU2 62oC. These are under massive stresses graphically running a custom fan profile with the highest speed of 60% to keep those temps at those levels. I know I can go higher on fan speeds, but don't want to go any higher than 60% due to noise.
