CrossFire without Master Card
I cant find it now, but im sure someone here has it running, and the performance difference is next to nothing, going by this article here , which you probably saw in the thread i did link to. :D
x1950 Crossfire done the master card way only gets about 335 points more than that in 06, so games should be about the same, couple of frames diff probably. :)
from what that site said it seems that its pointless unless you want to run 16x AF etc......................................
brb nicking the 1900 from mums PC.
Im going to nick the X1900XT from my bros PC.
See what happens :D
:eek:
Thieves!
Let us know how it goes though! ;)
The $6m Dan said:
I assume this still requires a crossfire compatible motherboard?
It would be good if it didn't, but I'm not holding my breath.
If it wasn't crossfire compatible, it would only have 1 PCI-E slot :D
Quick side question:
If you can get modded drivers to do SLi on a Crossfire board, can you get drivers to do Crossfire on an SLi board, like the nForce chipsets?
