CRT monitor problems
Permabanned
12 Sep 2005
England
hi guys, in the middle of my screen the text is "fuzzy", every where else is fine, just the middle is blurry.
Any ideas whats wrong? Could it be the other monitor in the other room causing problems (Both monitors are next to each other, just with a wall inbetween)
It's a proview monitor i've had since 2003.
I very much doubt it's the other monitor, but why not not unplug one of them and see if the problem is still there ?
Reroute/ connect the VGA/ BNC leads.
Move other monitor (unlikely to be cause though)
I would say that if rerouting the VGA leads doesn't cure it it's an internal electronic problem with the monitor.
