Crucial Ballistix 2GB (2x1GB) DDR2 PC2-8500C5
N3M
N3M
23 Nov 2003
Cardiff
I bought this stuff not so long ago, and my cpuz is concerning me... can someone let me know if this sounds right...
Memory SPD
Module 1 DDR2, PC2-6400 (400 MHz), 1024 MBytes, Crucial Technology
Module 2 DDR2, PC2-6400 (400 MHz), 1024 MBytes, Crucial Technology
could the ram be not setup right and therefore be showing 6400??
I bought it from OcUK @ 03-may-07, so i doubt they would believe that fact that i just noticed this if it is the incorrect ram...
Cheers All
I think you need to set the clocks speeds yourself...
I know i had to set the speeds myself for my Crucial Ballistix 2GB PC2-5300C3
post a screen shot of the SPD table in CPUz m8.
Also you should have a part number on the Dimms and the anti-static bags - post this too.
But the SPD table should have the memory timings programed for 533mhz as 5,5,5,15,30,2T
N3M said:
cheers for the reply, but the ram i bought is 8500 and its showing as 6400?
You will need to set it manually in the BIOS. The timings will probaiblly be wrong aswell.
