Crucial Ballistix 2GB ok for an ASUS P5B Deluxe?
sweet! will get them bad boys purchased tommo then when I get some dollar in my bank. Been a long old month has january.
What voltage should they be run at 2.2v?
Cheers for the reply mate!
B
Hi mate
try it at 1.9/ 1.95 vdimm ,because the ram last longer that way
and DDR2 8500 will not be overclocked at all in that board ( unless you put the fsb above 533 mhz at 1:1 :D) so probably it do not need the full 2.2V to be perfectly stable
I mate
and DDR2 8500 will not be overclocked at all in that board ( unless you put the fsb abobe 533 mhz at 1:1 :D) so probably it do not need the full 2.2V to be perfectly stable
Hi Mate,
thanks for your info will take that onboard. I won't be doing much overclocking to be honest. So will be happy with the stock speed for the mo.
