Crucial Ballstix Overclocking
24 Jan 2007
Guildford
Hello, I am thinking of getting one of the Crucial Ballistix kit tonight. These are:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-088-CR&groupid=701&catid=8&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=MY-090-CR&groupid=701&catid=8&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=MY-093-CR&groupid=701&catid=8&subcat=
If anyone has any of these kits, what are they like and how do they overclock? What is your current overclock and what have you had them up to and using what other hardware. Please provide screenshots if possible and the spec of the rest of you system. Please be quick as I will most probably be ordering tonight. :D
just search and you'll find people's results.
Here's me testing mine when I first got my new setup...from what I've seen 1000mhz @ 4,4,4,12 is pretty easy:
And I run it daily at the frequency in my sig on the stock 2.2v...might set it back to 1125mhz though....
black86 said:
gurusan which crucial ballistix have u got out of the three mentioned tho?
The PC2 5300 kit ;) It's been said that they all use the same chips though as far as I know this is just a rumor. But from what i've seen they all achieve pretty similar clocks.
