** CRUCIAL BRINGING IN THE HEAVY WEIGHTS - ELITE IS COMING - PRE-ORDER SPECIAL PRICING! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Crucial are bringing out the Big Guns with their Elite range, carrying on the excellent tradition of great compatibility and performance of the Sport range, the Elite feature superb high quality heatspreaders and much tighter memory timings for better performance:-
I am offering them at these very low special Pre-Order ONLY prices until Monday AM, stock is due today/tomorrow or Monday at the latest:-
Crucial Ballistix Elite 8GB (2x4GB) DDR3 PC3-16000C9 2000MHz Dual Channel Kit (BLE463D2001CE1TXO.Y16F94) @ £79.99 inc VAT
Crucial Elite high performance memory module 8GB (2x4GB) 2000MHz 9-11-9-27, 1.55V-1.65V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Crucial Elite memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 2000MHz
- Elite heat spreader for performance
- Packaged together immediately following system test
- Tested together at 2000MHz, Vdimm = 1.60V, at latency settings of 9-11-9-27 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-11-9-27 values at 2000MHz, 1.60V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1866MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
- Bulldozer compatible
Was [£99.99] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Crucial Ballistix Elite 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit (BLE2CP4G3D186HCE1TX0CEU) @ £74.99 inc VAT
Crucial Elite high performance memory module 8GB (2x4GB) 1866MHz 9-10-9-27, 1.55V-1.65V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Crucial Elite memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1866MHz
- Tested together at 1866MHz, Vdimm = 1.60V, at latency settings of 9-10-9-27 on Intel DDR3-based motherboards.
- XMP 9-10-9-27 values at 1866MHz, 1.60V
- Lifetime Warranty
Was [£94.99] Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
Crucial Ballistix Elite 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLE2CP4G3D1608DE1TX0CEU) @ £55.99 inc VAT
Crucial Elite high performance memory module 8GB (2x4GB) 1600MHz 8-8-8-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Crucial Elite memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- 100% tested at 1600MHz in Intel based motherboards
- Lifetime Warranty
Was [£69.99] Inc. VAT
Only £55.99 inc VAT.
ORDER NOW
Crucial Ballistix Elite 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLE2CP2G3D1608CE1TX0CEU) @ £35.99 inc VAT
Crucial Elite high performance memory module 4GB (2x2GB) 1600MHz 8-8-8-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Crucial Elite memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- 4096 Megabytes of DDR3 memory
- Two matched 2GB modules
- Lifetime Warranty
Was [£39.99] Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
If you want not only some of the fastest and highest quality memory available then look no further and remember Crucial has the best RMA service in the UK by far with lifetime warranty. :)
Oh and a few SPORT deals for you:-
Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (BL2KIT51264BA160A) @ £37.99 inc VAT
Overclockers UK brings you one of the most notable names in system memory today.
These high performance modules are engineered to deliver the fastest, most reliable memory for gaming and performance enthusiasts. Upgrading has never been this easy!
If you‘re new to performance memory and like what Ballistix has to offer, the Crucial Ballistix Sport Series is a great place to start. This line was created for mainstream users and general enthusiasts. They feature heat spreaders for thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility.
This memory allows you to plug it into your system and get back in the action for an affordable and easy upgrade, ideal for any Intel Sandybridge or AMD AM3 based system.
- PC3-12800 1600MHz CAS 10-10-10-28
- Designed for Entry-Level & Mainstream Users
- Integrated Heat Spreaders
- 1.5v VDIMM
- Dual Channel Memory Kit, Ideal for any Intel Sandybridge or AMD AM3 based system
- Limited Lifetime Warranty
Was [£53.99] Inc. VAT
Only £37.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport 4GB (2x2GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (BL2KIT25664BA160A) @ £21.98 inc VAT
Overclockers UK you one of the most notable names in system memory today.
- 1.5v VDIMM
Was [£26.99] Inc. VAT
Only £21.98 inc VAT.
ORDER NOW
Great time to buy some memory this weekend. :D
This stuff looks exceptional, think I may trade in my boring XMS3 for 16GB of the 1600MHz elite.
*Sigh* Ordered Kingston HyperX Genesis Grey 8GB (2x4GB) Last night for £47.99 as the cheaper Corsair Vengeance kit would be too tall with my cooler and now you have the Crucial Ballistix Sport 8GB (2x4GB) for £37.99, order posted out today too so too late to change :(
