Crucial Pro OC DDR5 6000MHz RAM with an Asus TUF Gaming B650-Plus?
29 Aug 2010
Cornwall
Does anyone know if this mother board will support this memory?
Looking on the website it's not listed in the memory section, but I'm not sure if that means it doesn't or that the list hasn't been updated (because it's not been tested).
Seems like some reasonably priced 6000Mhz RAM (6000Mhz I believe being a sweet-spot).
If you're looking at 48GB, I'd check the BIOS has support for it, but I can already tell you the TUF has a BIOS update that adds this.
The Crucial site says it's compatible in their compatibility checker, so that's a good sign (I think).
I was just going for 32GB, hadn't considered 48GB. Is 32GB already so borderline that people are going 48GB?
