Hi everyone!
I have a relative with a poorly iMac and wondered if you lot could give some advice. I know the Mac basics but I don't own one myself. I'd rather double check my advice with the experts here before passing it on.
My relative owns a iMac purchased in late 20006. It's a 20" G4 model, like the one in this photo. Sorry, I don't know the exact model number and spec but I beleive that it runs a 1.25Ghz G4 CPU and has 256MB of RAM. Worst case scenerio, as far as I can tell, is that it has a 1Ghz G4 CPU and 128MB of RAM.
The main problem is with iPhoto. There's around 4,000 photos on the HDD and iPhoto has become unuseable. The app constantly hangs and it's impossible to delete photos from it. The Mac also has a weird problem in the mail client where it won't show e-mail folders beyond the basic (inbox, outbox, etc). Generally, all of the iLife apps have become very quirky.
So I think there's three solutions I can use in parallel to get the iMac back on its feet:
1) Buy some more RAM. Apparently I can add a 512MB module quite easily, bringing the total RAM up to 768MB (depending on how much it started with).
2) I could install the latest version of Mac OS X (10.6 aka Leopard?).
3) I could run some system tools like a defragger over the system.
I'm definitely going to do 1+3. Potentially 2 if it's worthwhile. The cheaper the fix, the better.
So the questions I have are:
a) Will the latest version of OSX run sufficiently well on a 1.25Ghz G4 CPU with 768MB of RAM? Are there any Apple programmes which aren't compatible with PowerPC CPUs at the moment?
b) I assume that installing the latest version as an upgrade won't wipe the user files off the HDD?
c) Is the latest version of iPhoto an improvement over the version available two and a half years ago?
d) Does OSX come with system tools like a HDD defragger?
Any other general advice is welcome. No, buying a new iMac is not an option.
Thanks.
Thanks.
