current VCDS reports my Vw Scirocco Preface lift 2014 has the steering wheel module : 5K0 953 569AG OEM fitted
with a Highline mdf
I have bought this Stalk : http://www.ebay.co.uk/itm/VW-GOLF-V-VI-PLUS-SCIROCCO-JETTA-TIGUAN-TOURAN-INDICATOR-STALK-CRUISE-CONTROL/262349240386?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
VW PART NUMBER: 1K0953513A
Shows that it is compatible with my car and as far as im aware all vw cars past 2006 has the pin 13 diagostic wire from module to ecu already fitted...
my problem is the cars OEM slip ring,
Im not sure its compatible if i have a compatible steering wheel module for cruise control coding via vcds
and compatible stalk to fit
would the cars OEM slip ring be compatible ? or would i need a new Slipring and if so could someone tell me what part number i need thats compatible or a link to the part
thanks.
with a Highline mdf
thanks.
