- 13 Jan 2010
- A box in the Astral Plane
I've got the cash now to afford the Lian Li PC-A70FB that I kept saying I would buy.
I've seen it for slightly less than it is on ocuk. Should I send it to get a window cut and to
be powdercoated?
The money required for the window + powdercoating would mean that the case is out
of my budget atm. If however, I was to just buy the case, or buy the case and a CNC
window cut, I could afford it.
Would it look ok with the silver interior and a window? (window design ideas needed!).
Or should I just wait until I can afford to have it powdercoated too (£300 for a case
is a lot of money...).
I'm currently using the rig in my signature, and I'll later be swapping the 5770CF
for a 480 or 69xx card (under water). Also throwing the H50 for custom water.
A red/black theme is what I'm after, but would it look ok without the theme, and just
silver interior?
*edit* I forgot I have no signature anymore!
Asus P6t Deluxe,
OCZ Reaper Memory,
Custom water (black or red tubing/fluid),
Corsair HX650.
Pretty much all that can be seen when you look inside, plus either black or red cable braiding.
Infact, I could just have everything black, and only the interior of the case would be any
different (silver). Containing no red at all.
be powdercoated?
silver interior?
Asus P6t Deluxe,
OCZ Reaper Memory,
Corsair HX650.
Guess I'll need the funds for powdercoating..
