So far my total crunching power is
AMD Athlon 64 3200 (stock 2000mhz atm)(flagship rig)
AMD Athlon 64 3000 (stock 1800mhz)
AMD Athlon XP 2200 (1890mhz @ 1.75v)
AMD Athon (1200mhz @ 1.79v)
Intel Pentium 4 (stock 2500mhz)
Soon I should also be adding an AMD Athlon XP 2600 to the list.
And Eventually my new watercooled dual Opteron 270 flagship.
The best bit is all of the above except for the Pentium are in a small Air Conditioned room
I also have two borged machines both 3Ghz HT Pentium 4's, though I will be unborging one of them as it's running too hot and isn't on that much.
Now the big question.
Do I need more computing power?.. for some reason I still feel inadequte...
You mean, "Can I ever have enough computing power?" And the answer is always no
