Cryorig M9i cpu cooler brackets touching motherboard capacitors
19 Jun 2018
Hi all. I am about to install a Cryorig M9i cpu cooler on a Gigabyte B360M DS3H motherboard. The metal cooler support brackets are partially covering the boards capacitors. In fact to tighten the screws, the brackets touch the capacitors. Would this be a problem? i.e. risk of electrical short or heat transfer from cooler to the brackets? Thanks
Electrical short is unlikely but stress damage is highly possible and it won't help heat...
Check you've got all the components of the cooler positioned/assembled correctly, and see if it can be mitigated by rotating the bracket.
