Crysiis 2 invalid serial
30 Dec 2004
Worcestershire
Just got Crysis 2 LE version on DVD & when I go to put in the key to validate it it tells me 'key invalid contact customer support for more information:mad:
Purchased from reputable Jersey based retailer P.C, there seems to be quite a few complaints regarding this but I can't find a fix, see if I get a reply from support :rolleyes:
I have the exact same problem and i bought it from the same place as you and as far as i can see it is a server problem which is talked about at mycrysis.com
There are quite a few complaints about multiplayer keys suddenly invalid or already in use but I can't even get to single player
Just give them a call on the support line.My problem was, my serial key became invalid as I had used it 5 times, spoke to a guy and explained what id done.He gave me another serial key over the phone done and dusted.
Acute embarrassment :rolleyes: special edition version comes with 2 keys & someone I know put in the one for extra content first as he hadn't noticed the other one on the back of the manual :p :p
I will add that I read that on the net that lots of others did the same thing,lol
Yeah, it's the 20 character cd key you want.
The 16 character key is for limited edition loot. (Which afaik, still doesn't work?)
"someone I know" hmmmm
I did the same thing, just yesterday.
Much trickier to solve was getting a ****ing MyCrysis account login to work properly. I can't believe that's still flaky.
